scas wrote:use only genuine bearings as theyre a bit of a faf to change. takes about an hour. wheel off. pads out. caliper off. big center nut off, if it has abs, sensor disconnected. thing big nut screwed to off. loosen the 13mm nuts that connect disc, take out torx bolts thru holes in the hub, they can be tight, use a good socket.
there are various ways to separate the hub from the knuckle, my prefered way is a hammer and bolster between the hub and knuckle until it moves a millimeter. then a 4 foot prybar front and back between the hub and knuckle- separates them in about 30 seconds.then take out the 13mm bolts you loosened.
3 options now, either grind the bearing off and press, not drift, the new bearing on or buy a bearing with the flange attached. then stick it all back together, or a garage will charge about 100 quid labour.
scas wrote:Knuckle is the bit that the shock and hub bolt to, hub is the flange, disc and bearing, and flange is the bit that the wheel bolts to
avromo wrote:thanks, i understand its important to get the torque correct on the driveshaft nut, what do ppl use for this ? torque wrench i have access to does not go that high ?
scas wrote:As above, all the big nut does is hold on the abs ring, or nothing if you have no abs.
