indacus wrote:Engine seems to start and run fine from cold or lukewarm, but once normal operating temperature has been reached it will not restart until cool. You turn key and it sounds like engine has started, but it dies as soon as key is released. AA patrol didn’t know what problem was but generated this fault code: System : Engine control 1 - ZZH / Diesel CR/EDC DEN C1.1P068A - Main relay. Error Message : Shutoff too early. He seemed to be suggesting this code was pretty generic and not all that specific. Garage have told me they’re not interested (needle in a haystack…). Please, does anyone have any ideas?! Thanks in advance.
Interesting.Because the TDDi system starts on the position sensor in the injection pump (which will be fine) and then switches to PCM (therefore crank sensor) control as soon as it's going. So it just thinks the engine has stopped and switches the fuel off.
richardstubbs wrote:... It might have swarf on the end but I doubt it because that would affect cold starting too. If it has then bad luck.
Jim Archer wrote:That is the thing, the attracted swarf is a hot engine issue, the Hall Effect sensor builds a small magnetic field in use, that attracts the swarf which then affects the signal quality enough that it then won't start at low response values - the PCM is looking for a sharp rise/step in the signal, the swarf smears that step to more of a ramp, and that doesn't register til it's too late.
Once shut down, the field takes a few seconds to collapse, the swarf - which will now be slightly magnetic in itself - attracts to the iron core of the sender, and both slows the field collapse in the core, and smears the signal at cranking. Once it's cooled, the field is naturally weaker, so the majority of the swarf falls away, til next time ...
Because the TDDi system relies on both pump and crank inputs to fire, it knows it's being cranked, but doesn't 'see' the crank/CPS signal til it's either too late, by which time it's outside the timing window set by the pump sender pulse.
Jim
What's for sure is if replace components that's not where the fault is then usually results the exact same problem plus if unlucky there's risk of counterfeit/ low quality parts tooWhat should I look at next - starter motor/crankshaft sensor? Garage still reluctant to get involved investigating
That sounds easy one to try. An empty dishwashing liquid bottle filled up with water ready to squirt the whole contents over the sensor.amlav wrote:Crankshaft sensor ? Pour some cold water on the crankshaft sensor when engine hot and won't start . It used to happen on older type Jeeps too . Make sure is the Crankshaft sensor ....not the camshaft sensor you pouring the water on to .
