Ford Transit 80 SWB 1998 "WHINE"
Postby Paul Kenning » Mon Dec 05, 2005 10:07 pm
Just recently i have noticed a whine from the rear when creeping up to 60mph it goes once it drops under 60 mph, as i do a lot of motorway driving it is starting to get on my nerves, has anybody got a cure or know what the problem is.
Paul
Sad Person who owns a Transit 80 SWB
Paul Kenning
Postby MrMPuk » Mon Dec 05, 2005 10:30 pm
Sounds like the diff to me, give the level a check in it first off.
Question
Postby WhiteVanMan » Mon Dec 05, 2005 10:48 pm
How yould you check the oil level and what should i put in it? because my diff has been driping for a while now? :o better check it,,,
Thanks,
WhiteVanMan
Postby MrMPuk » Mon Dec 05, 2005 10:49 pm
There's a plug on the front nearside, which is the level/fill point.
Postby WhiteVanMan » Mon Dec 05, 2005 10:59 pm
ok cool, will have a look for that soon,. thanks,
WhiteVanMan
Re: Level
Postby Paul Kenning » Mon Dec 05, 2005 11:51 pm
Recently done on service including gearbox, but checked it anyway rear axel oil ok.
And i used to live in Fareham, Beaufort Ave in 1964
Paul
Paul Kenning
Postby MrMPuk » Tue Dec 06, 2005 12:01 am
Did you do the service? If Ford did it they will not have changed the gearbox or axle oil as they are both non service units! I know Beaufort Ave well, just around the corner from me, although you lived 11 years before I was born!
Re: Service
Postby Paul Kenning » Tue Dec 06, 2005 12:12 am
They suggested i had it done as i was hacing the gearbox done.
Our house was the last one built, before they started up the hill, Remember the Steam Trains running at the back of the house. Used to play in Bluebell Woods above the Tunnel, Harrison Rd School untill they moved us to Bishopsfields, Yes it was a long time ago. Back to the Transit, is it expensive to replace the axel or have the diff reconditioned?
The van is worth keeping as i have modified it for my own purpose so if i have to spend on it so be it.
Paul
Paul Kenning
Postby MrMPuk » Tue Dec 06, 2005 12:15 am
What we need to see then is some pictures!
Re: Pictures
Postby Paul Kenning » Tue Dec 06, 2005 12:30 am
Ok, Pics will be added tomorrow if it stops raining.
I was in Highlands Rd about a year ago, came of the M27 for a look see, went down Arundle Rd, noticed Fourboys is still there, Fareham and the estate has changed a lot over the years. Thanks for your input
Paul.
Paul Kenning
