heitam wrote:My MK7 2.2Tdci fwd 92 kW dpf regens every 30-50 miles ! What forces it to do that often ? No fault codes. Started to act like this suddenly. Anybody had that situation ?
heitam wrote:Hey, As mentioned, no fault codes whatsoever !
So, end of the story. Just bought new batteries yesterday and thats it. I consider myself lucky to finalize the issue with 252EUR investment in new batteries as my garage told me that ok, lets start investigate the case with changing the injectors and finish with new turbo...
I was 'struggling to understand' how just replacing the batterys resolved the issue. The only working theory I could think of was: that the alternator worked harder for the first days, while the batteries were "settling in", and that soaked the DPF in more fire.heitam wrote:Iˇm speechless as often regens back again. 2 days after batteries (twin setup) change ok and now again everyday regens. Was so happy that battery change seemed to solve the problem, but short success.
I do not understand what forces dpf to regen so often. Anyone have ideas ?
heitam wrote:I do not understand what forces dpf to regen so often. Anyone have ideas ?
Yes, absolutely. And also if the 5th glowplug isn't setting light to the fuel spray, then with the not properly burned fuel have a hard time re-genning, or might not even regen at all. Salt corroded wires underneath are very common problemAltransit wrote:More often than not, this is because there's a problem with the vaporiser, as mentioned by GT addict in a post above. Maybe that's a good place to start looking
heitam wrote:As dpf is not blocked and no any faults shown so far however driven couple of thousand km, then in my opinion dgr cycles are completed every time when regen happens.
So there must be something what forces dpf to regen again and again.
Talk to the specialist and they suggested not to touch at the moment and wait while some fault code appears or goes limp mode etc.
It would be stupid start changing turbo, fuel injectors, etc. all expensive stuff. So go figure, whats the right thing to do...
Just afraid if frequent regens eventually burn the dpf cells prematurely or something else ruins...
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot]
