Fitting a v6
Fitting a v6
Postby Decky75 » Mon Jun 05, 2023 12:39 pm
Hi guys, is there a fitting guide on here for putting a v6 into a mk2 with an MT75 box?
I’ve tried searching can’t find anything.
I really need to know what mods and parts I need. Please can someone help
Decky75
Re: Fitting a v6
Postby Luke » Tue Jun 06, 2023 5:29 pm
you need the ford adapter plate and clutch etc.
unfortunately a rare part, especially these days :(
i did mine years back i got the parts from a v6 ambulance
Re: Fitting a v6
Postby Decky75 » Tue Jun 06, 2023 9:01 pm
I’ve got a transit pinto with an MT75 box is that the same adapter plate?
Decky75
Re: Fitting a v6
Postby Luke » Tue Jun 06, 2023 10:04 pm
Decky75 wrote:I’ve got a transit pinto with an MT75 box is that the same adapter plate?
no different but some on here have modified those to fit if it's still on guy88 did his mk3 quite a few years back
Re: Fitting a v6
Postby Decky75 » Wed Jun 07, 2023 8:32 pm
Do you know what engine mounts are needed?
Decky75
Re: Fitting a v6
Postby Neil » Thu Jun 08, 2023 7:14 am
Decky75 wrote:Do you know what engine mounts are needed?
v6 mk 2 mounts like luke says you can still find these from a breaker
Neil v6
Neil
Re: Fitting a v6
Postby oldskooler » Wed Jun 14, 2023 10:01 am
i recently did a v6 conversion on my mk2 van using a 2.9 efi colonge engine from a granada....
i used the complete kit from a mk3 2.9 ambulance....the svo adaptor plate, large flywheel, engine mounts and exhaust manifolds which are designed to clear the large adaptor plate for the mt75 box...
the factory transit v6 parts are hard to find, but do turn up occasionally.....
ive got another kit, but im keeping it for a possible v6 conversion on my bullnose mk1, as im delighted with how the mk2 drives with the v6 lump!!
if it was only a single wheel swb van, you may just about get away with using a mk3 transit type 9 box along with a 2.8 granada bellhousing and flywheel, but the torque of the v6 would have the type 9 box on its limits i would think....
i may have a spare set of engine mounts id consider selling, but im based in ireland....
oldskooler
Return to Mk 1 & 2
