Kardaani wrote:Resistance is so small it´s impossiple to relibly measure with multimeter. Figured it out with Ohm´s law but i cant remember the result. Below one ohm it was. Might be 0,6 Ohms but not sure.
gregd72002 wrote:Problem fixed. Got broken wire too and re-wired with a resistance wire. We calculated that the original resistance was around 0.25 Ohm.
It works fine.
Anybody knows what is the small component (diode?) that runs across the ends of the resistor, and what is its purpose?
It works fine.
