Ford Transit Minibus 2006 Dash / Speedo Issue
Postby mark.webb84 » Thu Oct 19, 2023 1:58 pm
Hi, hoping someone can advise the way forward with an issue I have.
My Scout Group has a Ford Transit 2006 (56) 15-seat minibus. It has issues with central locking in that the key operation seems temperamental, however, an issue I have just noticed may be behind this issue.
The speedo/dash display seems to be constantly recalibrating. The speed needle drops and resets. This happens when the engine is off and/or key is not in the ignition.
Could it be fuses? The fuses look slightly corroded but are intact. Or is it likely to be a wiring fault?
Any suggestions are welcome.
Many thanks
mark.webb84
Re: Ford Transit Minibus 2006 Dash / Speedo Issue
Postby Altransit » Thu Oct 19, 2023 2:30 pm
Welcome to the forum :D
Firstly, as it was a changeover year, we need to establish whether it's a Mk6 or a Mk7 :? .
Look at my avatar, does the front look like the silver van on the left, or the white van on the right :?:
Postby fortyeight » Sat Oct 21, 2023 5:36 pm
if the fuses look a bit crap clean them
fortyeight
cron
