front Wheel bearing mk5 190
Postby CG_Maintenance » Thu Nov 27, 2008 8:23 pm
how hard is it to do the wheel brearing on these
think mines on its way out
http://www.cgmaintenance.co.uk
Reactive Glazing Repairs & Instalations
Let your balalaika sing
What my guitar wants to say
(00==[][]==00)
CG_Maintenance
Re: front Wheel bearing mk5 190
Postby transit killer » Thu Nov 27, 2008 9:10 pm
Its a straightforward job.
1.Jack up
2.Wheel off
3.Remove caliper and carrier together
4.Remove bearing dust/grease cap
5.Remove split pin, locking cap and bearing nut and washer.
6.Pull off hub and disc
7.Remove inner seal and both inner and outer bearings, either knock out or press out the two bearing races from the hub.
8.Press in new bearing races, fit inner bearing back in place and fit the new inner seal.
9.Push hub back into place and fit outer bearing and add grease.
10.Refit the washer and nut, tighten up until you feel the nut becoming tight(would guess at 20nm) then back off about a 1/4 turn or until find the point where the nut is becoming free again .(hard to describe but easy when you do them regularly).
11.Check that the wheel hub rotates freely with no free play in the bearings.
12.Refit locking cap along with split pin and fit grease cap.
13.Refit caliper and carrier.
14.Wheel back on
15 Jack down, job done
Hope that helps! :wink:
2004 Transit 350 LWB Recovery
transit killer
Postby CG_Maintenance » Thu Nov 27, 2008 10:13 pm
Only problem
The press
looks like a job for the weekend then
(00==[][]==00)
CG_Maintenance
Postby MrMPuk » Thu Nov 27, 2008 10:18 pm
Just knock them in and out with a drift, I've never used a press to do them.
Postby transit killer » Thu Nov 27, 2008 10:37 pm
MrMPuk wrote:Just knock them in and out with a drift, I've never used a press to do them.
me either, they drift out easily enough
transit killer
Postby rumpelstiltskin » Thu Nov 27, 2008 11:27 pm
I've just done this too on my MK4 and didn't need a press. :wink:
rumpelstiltskin
Postby Luke » Thu Nov 27, 2008 11:35 pm
just find a socket that doesnt go all the way through and once its resting on the outer race give it a smack (you can even use the 1/2" bar in the wrong way round) and it'll fly out :D
Postby CG_Maintenance » Fri Nov 28, 2008 2:02 am
chears
any ideas how much a bearing is
(00==[][]==00)
CG_Maintenance
Postby jckm2000 » Mon Mar 25, 2024 6:23 pm
I need to do mine this week, searching for parts on eBay two types are coming up, tapered and non tapered.
Mine's a 1996 twin wheel 190, are mine tapered or non tapered??
MK1 V4 flatbed (long gone)
1978 MK2 pinto
1996 MK5
2003 MK6 (now gone)
1967 Morris WF
jckm2000
Postby Chug » Mon Mar 25, 2024 9:20 pm
Chug
Postby gotgcoalman » Tue Mar 26, 2024 12:37 pm
Tip...........
Put the outer bearing races in the freezer over night.
You'll find they go in without having to pound or press them in.
Once they warm up to the ambient temperature (depending on time of year) they'll be a snug fit
Too bloody quiet :shock:
gotgcoalman
