Mk 5 Completely dead. Electrical fault?
Postby Gludenscrude » Thu May 30, 2024 9:19 am
Hi,
I wonder if anyone has any ideas, I bought a 1997 Mk 5 Auto sleeper camper van a couple of weeks ago and 5 days ago as I was driving the Flasher relay was making a funny noise. So when I got home I pulled the relay and did something which in hindsight might have been stupid. Once I had removed the Flasher Relay I turned on the ignition and everything lit up as normal though I didn't try and start the van. The only weird thing was there was a high pitched electronic single note sound whenever the drivers door was open. Anyway I locked up the van, went inside and ordered a new relay, It took two days to arrive and just before I went to install it I tried the key again and there was nothing there, nothing at all. I installed the flasher relay and still dead. I thought flat battery so went to charge it with my battery charger but the charger refused to charge the battery. I took the battery off thinking the battery had died but once I removed it I re-hooked up the charger and it not only tried to charge it but within about 5 seconds was saying it was fully charged. I reinstalled the battery but still nothing when I turn the key.
So does anyone have any ideas of what I need to do to fix this please, FYI I am on the Fylde coast of Lancashire and am not very technical.
Gludenscrude
Re: Mk 5 Completely dead. Electrical fault? SOLVED
Postby Gludenscrude » Thu May 30, 2024 11:13 am
I feel somewhat of an idiot, I trusted my battery charger, chatting to a mate he suggested just try a different battery just in case and straight away that sorted the problem, my battery charger lied to me and my battery was kaput!
Gludenscrude
Postby andz327 » Thu May 30, 2024 11:38 am
Are you sure it was the flasher relay that was making the noise ???? I would check all the earth cables first especially the one from chassis to engine
andz327
