TOURNEO CONNECT NESTARTUJE
Postby rakev » Sun Jul 14, 2024 7:46 am
zdravím.
tourneo connect 1,8 tdci 66Kw 2012 nestartuje. Při běžné jízdě najednou motor zhasl a již jsem nenastartoval. Po odtažení domů jsem zkoušel vše možné ale ani diagnostika nevypsala žádnou závadu. Motor normálně točí nafta do vstřikovačů jde. Zkusil jsem startovací spray a motor okamžitě chytil. Nechal jsem ho cca. 5 min. běžet vše bez problému. Po vypnutí opět nejde nastartovat. Nejvíce divné mi připadá ,že zhasl za jízdy. Za každou radu čím by to mohlo být budu vděčný. Díky Petr
rakev
Re: TOURNEO CONNECT NESTARTUJE
Postby metalworker0 » Sun Jul 14, 2024 1:45 pm
translated to.
Hello.
tourneo connect 1.8 tdci 66Kw 2012 does not start. During normal driving, the engine suddenly went out and I did not start it. After towing it home, I tried everything possible, but even the diagnostics didn't show any fault. The engine runs normally, diesel goes into the injectors. I tried the starter spray and the engine seized immediately. I left him approx. 5 minutes run everything without problem. After switching off, it cannot be started again. The strangest thing to me is that it went off while driving. I will be grateful for any advice on what it could be. Thanks
Postby metalworker0 » Sun Jul 14, 2024 1:51 pm
if its seized - as you say
i suggest there is a problem with upper timing belt or lower "wetbelt"
suggest you first take upper belt cover off ..and examine condition of belt.
Re: TOURNEO CONNECT it won't start
Postby rakev » Sun Jul 14, 2024 2:00 pm
thanks for the response. No, the engine starts after injecting the start spray, but after turning it off, it cannot be started. fault-free diagnostics
rakev
Postby metalworker0 » Sun Jul 14, 2024 2:17 pm
Thinking, look for leaks in the fuel pipes ..this will be a leak that sucks air into the pipe...this leak could possibly be at the bottom of the firewall/ bulkhead where the pipes bend near subframe. look for rubbing marks on pipe.
