High oil temp problems 2.2TDCI 130-150 Degrees
Postby Transity2.2TDCI » Fri Nov 29, 2024 9:26 am
I have a 2012 Ford transit 2.2TDCI and my Autel says the oil temperature is between 130-150 degrees celsius, isnt that mutch to high? My coolant temperature is 82-88 degrees. I change oil 5/30, change termostat housing, waterpump. EGR is deleted and DPF is not threre anymore. Please help???
2012 Ford Transit 2.2TDCI 350
Transity2.2TDCI
Re: High oil temp problems 2.2TDCI 130-150 Degrees
Postby tranmx2 » Fri Nov 29, 2024 9:37 pm
Eng oil working temp about 100 to 110 C.
The oil is cooled by the coolant. So lowering the coolant temp could lower the oil temp. If the fuel injection timing is wrong the eng' could run too hot.
Is the sensor reading correct? Is Autel reading the temp correctly? An IF temp' reader could be used to determine the temp' at different places, were £20.
There maybe different coolant thermostats - I think mine opens at 88 C. Is the present coolant being cooled sufficiently? What is the eng' coolant temp? Is there dirt on the oil cooler? Is coolant flowing to and through the cooler? Is the radiator blocked externally/internally? Pipe inner colapse, rag left in, coolant pump not rotating.
The consul gauge on mine shows about 90. Forscan shows about 70.
tranmx2
Postby tranmx2 » Fri Nov 29, 2024 11:30 pm
Transity2.2TDCI wrote:I have a 2012 Ford transit 2.2TDCI and my Autel says the oil temperature is between 130-150 degrees celsius, isnt that mutch to high? My coolant temperature is 82-88 degrees. I change oil 5/30, change termostat housing, waterpump. EGR is deleted and DPF is not threre anymore. Please help???
Not seen an eng' oil temp gauge on the consul nor seen the oil temp' on Forscan. There's no sensor on the oil filter cooler housing for oil temp'. Did not see any sensor on the engine for oil temp' except near where the oil return for the turbo is which is supposed to be a sensor for oil level.
tranmx2
Postby Transity2.2TDCI » Sat Nov 30, 2024 8:34 am
There is a sensor nerby the oilfilter housing, maybe this is oil pressure?
Transity2.2TDCI
Postby Transity2.2TDCI » Sat Nov 30, 2024 8:39 am
tranmx2 wrote:Eng oil working temp about 100 to 110 C.
Engine coolant temp is about 88, and i have flushed the radiator and its okay. I have circulate water throw the oil cooler and its good. Maybe autel readings are bad or the sensor is bad. Bacause its strange that Engine coolant is good and oil 140 degrees? This sensor is nearby the oilfilter...
Transity2.2TDCI
Postby Transity2.2TDCI » Sat Nov 30, 2024 8:47 am
But one thing, its very mutch pressure in the cooling sytem.
Transity2.2TDCI
Postby tranmx2 » Sat Nov 30, 2024 1:48 pm
Pressure in the cooling sytem ( has a relief valve in the cap at about 20 psi) is likely head gasket. Some have it that there can be a leak from the EGR cooler but the pressure in the coolant is likely to be greater than in the exhaust. A leak in any system can occur due to heat/cold/vibration the time a leak occurs is determined by the 3 possibilities/conditions/state. Use a sniffer (chemical test) in the header tank to determine the presence of gas.
On the oil filter/cooler housing is the oil pressure sensor - there is no other means on the 2012 RWD housing to connect another sensor.
A diagnostic reader needs to be suitable for the vehicle it is used on.
tranmx2
