Injector bolt length
Postby Radiofence » Tue Mar 25, 2025 12:25 am
Ive read there maybe 2 lengths for injector hold down bolts on the 2.2 transit custom. Is there any way to check with the vin?
Transit custom 2.2
Radiofence
Re: Injector bolt length
Postby metalworker0 » Tue Mar 25, 2025 1:05 am
LOOKS LIKE , there are two types listed for the mk7 2.2 - no sizes given, part numbers 1372386 and 1673999
https://www.catcar.info/ford/?lang=en&l ... g4NzkrMTMz
but on the custom 2.2, it only gives one part number and size at
M7 X 67MM
part number 1717583
https://www.catcar.info/ford/?lang=en&l ... gzNjcrMTMz
on the mk8 2.2 it gives one result - same size and part number as custom
so going by the car car info site
its: M7 X 67MM, part number 1717583 you'll be looking for.
barring its had an engine swap at some time
Postby Radiofence » Tue Mar 25, 2025 10:42 am
Awsone. Thanks Mark.
Transit custom 2.2
Radiofence
Postby andz327 » Wed Mar 26, 2025 2:55 pm
metalworker0 wrote:LOOKS LIKE , there are two types listed for the mk7 2.2 - no sizes given, part numbers 1372386 and 1673999
M7 X 67MM
part number 1717583
The two listed for mk7 are for euro 4 and euro 5
Like metalmickey said custom 2.2 euro 5 one type
andz327
Postby Altransit » Wed Mar 26, 2025 5:47 pm
I was under the impression that the two different bolt lengths are dependant on whether the injector clamp is the older, or the newer, (thicker) version 8)
Postby Radiofence » Wed Mar 26, 2025 8:40 pm
I've already ordered it, if it's wrong,I'll kick you on the shin!
Transit custom 2.2
Radiofence
Postby Dannny » Wed Mar 26, 2025 9:51 pm
Altransit wrote:I was under the impression that the two different bolt lengths are dependant on whether the injector clamp is the older, or the newer, (thicker) version 8)
Hi I have a 2015 custom 2.2 had awful problems with diesel leaking out the rocker cover, could it be I just need the updated clamps? Is that why they updated them? Thanks
Dannny
Postby Altransit » Wed Mar 26, 2025 11:19 pm
The clamps had been known to break under the pressure of the compression trying to push the injector out of the cylinder. The new clamp was reinforced to stop that happening.
Postby Radiofence » Wed Mar 26, 2025 11:26 pm
Do you know a part for that clamp? Else I might just put some sellotape over them to hold them down.
Transit custom 2.2
Radiofence
Postby Altransit » Wed Mar 26, 2025 11:43 pm
Radiofence wrote:Do you know a part for that clamp? Else I might just put some sellotape over them to hold them down.
That's just silly :!:
Gaffa tape is the repair material of choice these days :lol:
I'll find the numbers for you 8)
Postby andz327 » Fri Mar 28, 2025 11:37 pm
On the euro 4s the clamp was upgraded not heard of euro 5 clamp upgrades
andz327
Postby Altransit » Sat Mar 29, 2025 12:55 pm
andz327 wrote: On the euro 4s the clamp was upgraded not heard of euro 5 clamp upgrades
Ah OK Andz :oops:
I thought that the upgraded clamps came out about 10 years ago, after Euro 5's were invented :? In that case, the numbers I have will be useless for the OP :(
Return to Transit Custom
