"if you want to go full on you could take thermostat out / reverse flush it all, flush rad entirely up to you"
how difficult is this to do and hows it done? thanks
avromo wrote:"if you want to go full on you could take thermostat out / reverse flush it all, flush rad entirely up to you"
avromo wrote:Done thanks, useful that tool station open on Sunday.
For reference it drains probably 4.25l so had to also use a bit of water. Filled slightly over Max and ran for a bit went down to under min so topped up a bit of water. Will keep my eye on it.
knobby1 wrote:avromo wrote:Done thanks, useful that tool station open on Sunday.
The complete system holds a lot more than 4.25L....they're more like 10L.
DanMK7uk wrote:Correct, recommend doing it twice OP as I mentioned to get it pretty much all antifreeze.
knobby1 wrote:DanMK7uk wrote:Correct, recommend doing it twice OP as I mentioned to get it pretty much all antifreeze.
There's a lot of coolant which gets left in the engine block, oil cooler, hoses and heater matrix that usually gets forgotten....takes a bit of effort to flush them all through properly.
DanMK7uk wrote:Indeed.. hes had just water in so a good couple doses of antifreeze should be sweet for the winter..
Whilst your sunning ya self down there lol
knobby1 wrote:DanMK7uk wrote:Indeed.. hes had just water in so a good couple doses of antifreeze should be sweet for the winter..
We can "sun ourselves" all year round here....winter here is like your summer.
Summers can get quite brutal though...I remember a couple of years ago we had 13 consecutive days of 45C+.....now that was rather toasty. You could literally fry an egg on a tin can..
