metalworker0 wrote:ok 2.5 litre , auto 3 speed transmission , says two axles ... does that mean 4 wheel drive?
also a slow starter motor can stop these things firing up
and when you said 300k i thought miles... so not so high
knobby1 wrote:metalworker0 wrote:ok 2.5 litre , auto 3 speed transmission , says two axles ... does that mean 4 wheel drive?
No such animal as a Mk6 2.5 litre 3 speed auto.
mtnz wrote:Yes it is incorrect in the official link Lord Knobrrot, it's a five speed with ASM.
mtnz wrote:Back of a Weetbix packet most likely. Probably only the VIN/ Chassis is correct. Right now Im on the verge of having to sell this perfectly fine van as a dolls house because everything works but nothing actually goes and noone knows here in NZ actually knows much about them it seems, especially Ford. Buy it for 30k, Spend 8k on it, sell it for about 10k even though I have no idea whats actually wrong with it.
Hard to believe that they designed a van to pump diesel but not actually go. You'd think they would have prevented it pumping if there was an issue and if it was pumping fuel it would fire.
I'd love to get rid of this god forsaken engine altogether and put something simple and reliable in it instead of this mass of spaghetti cabling and overly complicated fuel pump.
Just keep the ASM and flog it because the ASM has never missed a beat despite everyone telling me it would fail, it never did. How easy is it to take out the ASM without damage?
mtnz wrote:Ford have used whatever their system is, and Ive used Forscan, others have used whatever theyve used. No error codes.
