meerkatmag wrote:It was originally a na engine with lucas cav pump. Bosch pump was fitted with turbo. I thought in this configuration you kept it pinned? I have checked timing and pins all go in easily. I will try advancing if you think it's worth a shot? But I think there's a problem with cylinder 1 valves. If I crack fuel pipe to 1 then the smoke completely clears. Other cylinders have no effect. So I think low compression on 1.
meerkatmag wrote:dumper wrote:Good old DI it’s now earned a GB sticker we use get one at work if you repaired a BrakeDown on the side of the road and didn’t need a recovery truck it this case GB was for got back .
Just a point on the smoke on your YouTube post on my mk3 trying to get a bit more power non turbo Bosch pump I advanced the timing on cold start with the wax stat for cold starting working that also advanced the timing for cold staring it smoked and ratted like yours until up to temperature and the wax stat put the pump back into normal driving mode I had too put the timing back to standard
Haha ill grab a GB sticker for sure.
Im going to mess with the timing and see if it has any effect. Im pretty sure it ran pinned before this so it seems strange. My bosch pump doesn't have any cable system for cold start so I don't think I can manually adjust it.
Chug wrote:Good video of all the journey and belt shredding incident and repair, and good you made it back home.
The pistons can't hit the valves if the timing is correct, only when it goes out of time when the belt shreds or snaps, but it may have been slightly bent and running and heat have let it "settle" back in, but a compression test would show any problems, a possibility is a damaged injector tip.
I would still try adjusting the timing a little each way to see if it makes any difference though.
