metalworker0 wrote:That's a hard one with no codes
Suggest you disconnect battery .. leave for 15 mins .. re-connect.
a blocked DPF can trigger adblue warnings .. so i read
If £400 clean was done in-situ (excessive charge, that would shock me) ./ and only half temporarily worked
... in cases of totally clogged DPF ... taking it off , blocking one end .. leaning against wall ,, filling with chemical couple maybe 3 pints or as much as a gallon .. then flushing with pressure washer is the ONLY next step - your job ... unless you want to pay more hundreds £££££ or new DPF
Possible causes of blocked DPF so soon after cleaning:
Vaporiser not working blocked
EGR open faults
Turbo actuator faults
Boost pipe leaks
MAf / air temperature sensor fault
Worn engine burning oil
Worn turbo leaking oil
Injector seals causing crankcase pressure which leads to high oil consumption
Constant short trips
Frag wrote:2.2 2015 with ad-blue,so is this a RWD 17 seater minibus ?
dumper wrote:Looking on YouTube at O’Reilly Auto‘s mobile mechanic some vehicles not necessary transit if you overfill it can cause problems he’s had to drain them off before to sort problems out. It might be worth taking it to him. He’s the man on Dpf definitely and as frag says the only 2.2 with addblue is a bus as they had to comply with euro 6 a year before vans did
metalworker0 wrote:Forgot ... DPF - leave overnight with the chemicals in it
further research suggests:
It's possible for adblue to crystallise in the tank .. so making the float stick .. the remedy is taking the tank off and cleaning it ..
i have read that buying adblue that has been left in direct sunlight all summer is not recommended (you often see it outside a petrol station on the forecourt).. so don't use your recent adblue batch .. if you find crystallisation in the tank.
metalworker0 wrote:Well, if you went to ford they would sell you the whole tank with the heater in it .. Probably i excess of £1000
ive just searched ebay and the heater is available separately ----cheapest £160
search words adblue heater 2.2 transit - but read below first
note: these add blue heaters are the same in other vehicles, ford, Peugeot , Citroen Vauxhall, even Mercedes etc , different tank same old adblue heater
You could get the price down by doing more research .. pull the heater out and it will have a manufacturers number on it... use that number to get the heaters price down in ebay search.
NOTE EBAYS SEARCH NOW WORKS DIFFERENTLY THAN YOU USED TO THINK,, you order the price lowest first ... looks lowest, but it really isn't , you only see the lowest prices "in the other sellers have these" results on a listing you are looking at .. repeatably pressing on these adverts , has other "adds" coming up that are lower... keep going until you see the lowest of the low -- the actual lowest i got it down to was £125 some results are way way and way down at the bottom
There are youtube videos on how to fix these problems with heater , level sensors etc ... they are detailed // dont search transit look at every make, as, as said same old heater... there are people out there who don't want to be ripped off and have worked out the cheapest fix for this problem whilst permanently fixing it the proper way and remaining legal.
would not be surprised if you could do this fix with brand new parts for under £50. with youtubes help
its not me that does this research its you .. as you are the one with the problem
dumper wrote:When you say it’s 100% and 9 lts im sure mine took 20 lts when the warning came on saying 500 miles range left approximately it would first come on anywhere from 350 the lowest to 740 the highest it flagged up
