Removing BCM how to unclip it!!
Postby pcatterall » Thu Jan 29, 2026 3:32 pm
With all sorts of cluster light and gauge issues I removed the cluster unit and had it tested! It was fine and I was advised to have the BCM tested. I have located it and can remove the various plugs but cant remove the BCM box itself!
Various videos suggest its 'just a push clip at the bottom' but after much pushing pulling and swearing I cant move it. Not sure if I have the right clip as the videos are poor quality (don't want to break anything either)
Has anyone done this recently please? All I can see is a curved plastic tag sort of thing at the bottom centre of the unit, this is where I have been focusing my attention!
Most grateful for any tips!
pcatterall
Re: Removing BCM how to unclip it!!
Postby Airthies » Thu Jan 29, 2026 7:17 pm
What generation of van as Mk7 and Mk8 are different.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby pcatterall » Fri Jan 30, 2026 10:41 am
pcatterall wrote:With all sorts of cluster light and gauge issues I removed the cluster unit and had it tested! It was fine and I was advised to have the BCM tested. I have located it and can remove the various plugs but cant remove the BCM box itself!
Sorted. Yes it is a curved black projection in the centre of the lower edge of the unit. I held it down with a screwdriver and the unit pulled out from the bottom. TIP. it may be better to remoth some of the connector plugs before doing this as they are easier to pull whilst the unit is in place. Dont forget to pull out the main power plug first ( small brown lower left hand side) There are two little plugs up at top left which may be better done once you have freed the unit.
I removed the unit and checked all the plugs and sockets for corrosion/damp, they were fine I removed the cover and inspected both sides of the PCB, there were no signs of corrosion, solder breaks or burnt spots. I returned the board and all the sockets. Presto every thing worked, tacho, lamps gauges, everything but, alas, only for a few seconds. I assume that the BCM board is fine and that there is a dodgy connection, I will try to locate which socket serves the instrument cluster and check it out.
pcatterall
Postby trnx » Fri Jan 30, 2026 3:08 pm
Indicates a poor earth.
Mk 7 E5 DPF RWD XLWB SRW
trnx
Postby johnpietila » Fri Feb 13, 2026 9:16 pm
Silly question but where is the BCM located ,please.
johnpietila
Postby johnpietila » Fri Feb 13, 2026 9:19 pm
Can someone tell me HOW many units are connected to th CAN Bus on 2010 VM Transit, please and where are they located.
johnpietila
Postby Altransit » Fri Feb 13, 2026 9:34 pm
johnpietila wrote:Silly question but where is the BCM located ,please.
It's underneath/behind the passenger fusebox. The fusebox itself unclips and swings out of the way to expose the BCM, which has another bank of fuses.
Postby pcatterall » Mon Feb 16, 2026 9:11 pm
Effectivly it is the rear fuse box hidden behind the front fuse box behind the glove box on the passenger side. Just drop the front box down and there it is!
pcatterall
