Mk7 2.2 2011bad starting
Re: Mk7 2.2 2011bad starting
Postby metalworker0 » Sun Mar 08, 2026 10:20 pm
Does it have an EGR cooler .. is it possible for water to run into the cylinders if its faulty.. would that make it hard to start .. and the starter motor sometimes inoperative.
Postby knobby1 » Sun Mar 08, 2026 10:28 pm
metalworker0 wrote:Does it have an EGR cooler .. is it possible for water to run into the cylinders if its faulty.. would that make it hard to start .. and the starter motor sometimes inoperative.
"ALL" Mk6 & Mk7 Transits have an EGR Cooler.
Lord Knobrot (Smithy)
Postby knobby1 » Sun Mar 08, 2026 10:38 pm
tompe wrote:I would say when it had pump and injectors I not heard about learns before so couldn't be 100 percent on that wot dose it entails
As mentioned, it's a service function....very few people do it as a part of a service, even more people don't even know about it. If parts of the high pressure fuel system are repaired or replaced, the learns should be done. No two pumps, injectors or valves are exactly the same even if they share the same part number. The learns will reset the system back to datum and tune the injector timing and flows to the pump pressure, flow and capacity.
You'll need Forscan and a "V-Linker" OBD-II cable.
Postby tompe » Fri Mar 13, 2026 7:56 am
Thanks for the reply what is the next step for a injectors and pump learn
tompe
Postby knobby1 » Fri Mar 13, 2026 8:29 am
tompe wrote:Thanks for the reply what is the next step for a injectors and pump learn
Do you have Forscan and a V-Linker cable..??
Postby tompe » Mon Mar 16, 2026 6:47 pm
No going to if I can find someone near me that can do it
tompe
Postby knobby1 » Tue Mar 17, 2026 12:47 am
tompe wrote:No going to if I can find someone near me that can do it
Get Forscan and do it yourself...if it fails the learns, you can diagnose it and just start again, Forscan is free and the cable is cheap....getting a garage to do it is time consuming ridiculously costly, especially if it fails to go through a few times, which is common....much more than the cost of the cable.
Postby tompe » Sun Mar 29, 2026 8:46 pm
Hi all sorry for late reply but got a learn done last week there are no faulcodes at all now but still a pig to start been told to change scv and pressure regulator on the rail would this be ur next steps
tompe
Postby knobby1 » Mon Mar 30, 2026 1:14 am
tompe wrote:Hi all sorry for late reply but got a learn done last week there are no faulcodes at all now but still a pig to start been told to change scv and pressure regulator on the rail would this be ur next steps
Can we assume it has passed the learns..?? If it has there is no reason to replace the SCV.....they don't have a separate fuel pressure regulator...the SCV does this job. There is an electronic pressure "sensor" on one end and a relief valve on the other end of fuel rail, no regulator.
Is the fuel filter still full after sitting for a few hours or overnight..?? Or is it hard to start when hot..??
