BCM wiring diagram pin data
Postby Con8030 » Sun Mar 14, 2021 8:48 pm
Hi all
Does anyone have Autodata if so could you send me a copy of the pin data for the BCM on a 2008 2.2l diesel 85ps please i can't find the data anywhere on the net
Thanks in advance
Con8030
Re: BCM wiring diagram pin data
Postby loot » Sun Mar 14, 2021 10:05 pm
What pins do you need mate?
07 350 170ps
Ids map here
loot
Postby Con8030 » Sun Mar 14, 2021 10:47 pm
Hi loot thanks for your reply
I'm having problems with the central locking not operating the rear door and side sliding door locks. I've traced the 3 wires from each of the lock actuators back to the BCM basically all 3 wires are grounding out. I've replaced and recoded the BCM but the problem is still the same.
I'm now trying to figure out the wires that go in to the BCM to trigger the central locking so I can trace those to wherever they go.
Con8030
Postby v8dave » Sun Mar 14, 2021 11:04 pm
All door motor drive lines are earthed through the bcm until a power pulse is applied to drive the motor.
To drive a motor the bcm switches power from fuse 78 to the appropriate motor wire with a relay that acts as a changeover switch, swicthing the motor wire from earth to power.
Lock all and unlock all use a single relay for each function since there are slices in the wiring loom.
Loot has pdfs of the wiring somewhere, diagram 501-14-00
v8dave
Postby Con8030 » Mon Mar 15, 2021 12:34 pm
Thanks v8dave that makes a lot of sense so I need to test the wires whilst cycling the central locking but if that doesn't help the the problem may be the signal to the bcm. I could do with the pin data to know which wires to look at
Con8030
Postby loot » Mon Mar 15, 2021 1:34 pm
Pm me your gmail and I'll fire it to you today
07 350 170ps
Ids map here
loot
Postby Con8030 » Tue Mar 16, 2021 6:44 pm
Thanks for the file loot I've had a quick look at it on my phone I'll print it off and hopefully this weekend I can start testing the components and hopefully narrow down the problem and finally fix it.
I was coming close to subscribing to autodata for a month just to get the pindata so massive thanks.
I'll let you know how I get on.
Con8030
Postby loot » Wed Mar 17, 2021 12:33 am
That's great, fingers crossed :D
07 350 170ps
Ids map here
loot
Postby Fordaudio » Sun Jan 09, 2022 6:47 pm
v8dave wrote:All door motor drive lines are earthed through the bcm until a power pulse is applied to drive the motor.
Thanks so much for this info it really has helped me maahoosively
Fordaudio
Postby Mecatronic » Sat Feb 04, 2023 8:46 pm
Con8030 wrote:Hi loot thanks for your reply
Hi, I have same problem, can you help me? Thanks a lot.
Mecatronic
Postby knobby1 » Sun Feb 05, 2023 2:23 am
Con8030 hasn't been back on here since 18th Sept 2021, so l doubt we'll ever know.
Postby Z1ggy » Sat Mar 18, 2023 4:51 pm
Hi
Is this diagram still available?
I have a problem with central locking fuse blowing.
My original post is here viewtopic.php?f=5&t=222015
Any help appreciated
Z1ggy
Postby DNDimitrov » Mon Mar 09, 2026 1:26 pm
Hello kind people,
I’ve been scratching my head for the past two days to find a way to add an aftermarket lock/unlock controller to my 2008 Transit.
My van only has one key fob and it doesn’t work. No response when pressing the buttons. I’ve already replace the battery, no luck.
So my next step was to find a second hand BCM that comes with both keys but learned that it’s not a direct swap and the “new” bcm needs to be programmed. This isn’t an option as I have no contacts of someone who’s willing to do that job in my area of Bulgaria.
So I ended up on getting a no name controller from AliExpress and hoping that it will do the job.
Is there a way to get my hand on the BCM Pin layout?
Best regards,
Dimitar
DNDimitrov
Postby knobby1 » Wed Mar 11, 2026 7:35 pm
DNDimitrov wrote:Hello kind people,
Best regards,
Dimitar
Does the RCS receiver LED flash when the FOB buttons are pressed..?? Do your interior cab lights work..??
Postby IanLa » Thu Mar 19, 2026 9:43 pm
I’ve got a slightly different issue but you all seem to know a lot about wiring :D
Does anyone have a wiring diagram for Custom 2019 I’ve got an issue with when I lock the van with FOB or key the doors all lock but the horn sounds as if there’s a door unlocked, tried replacing sliding door pins and rear door lock but no joy…Battery voltage is fine. Any ideas ..??
IanLa
