mk6
mk6
Postby marc1234567 » Thu Jul 31, 2025 9:14 pm
03 rwd ps 90 high top
how can you test an ecu if you think it is causing problems with the fuel pump. friend having lot of problems with fitting pump and thinks is ecu?
Previous mk 5 (2000) Luton body (2012-2013)
Mk 6 tddi 2.4 125ps RWD dropwell luton (2018 - present)
Mk 7 tdci 2.2 125ps RWD Luton / taillift (Aug 2021-present)
marc1234567
Re: mk6
Postby knobby1 » Thu Jul 31, 2025 9:32 pm
marc1234567 wrote:03 rwd ps 90 high top
Was your friend's pump virginised..?? You can't just plonk another pump on and expect it to work, needs coding.
What fault codes are you getting..?? ECU's rarely fail, it's actually called a PCM, "Powertrain Control Module".
The EDU/EDC electrical unit on the fuel pump is the most common fail point.
Re: mk6
Postby metalworker0 » Thu Jul 31, 2025 9:38 pm
you'll get these codes when its plugged into a scanner p1564 and p1664 - this could also be the wiring to the pump
These codes refer to the module that sits on top of the pump .. which is called and edc or edu
Re: mk6
Postby marc1234567 » Thu Jul 31, 2025 10:10 pm
they think they did code one of the pumps is with equipment on site and didn't work , then went and bought a new one from eurocarparts. ( that would be virginised right) . tomorrow , i will try to find out more details like codes and history of what has happened , as I think theyve tried various things like swapping looms and ecus and pumps. quite confusing. Can the virginising and coding be done with forscan?
marc1234567
Re: mk6
Postby knobby1 » Fri Aug 01, 2025 9:37 pm
marc1234567 wrote:they think they did code one of the pumps is with equipment on site and didn't work , then went and bought a new one from eurocarparts. ( that would be virginised right) . tomorrow , i will try to find out more details like codes and history of what has happened , as I think theyve tried various things like swapping looms and ecus and pumps. quite confusing. Can the virginising and coding be done with forscan?
New pump should indeed be virginised....new pumps are very expensive, but they rarely fail, it's usually the electronics on the pum which fail. The 90ps engine should have the VP-30 pump fitted...and yes the pump can be coded with Forscan.
Re: mk6
Postby marc1234567 » Sat Mar 14, 2026 10:21 pm
just remembered this.
i think he mixed up 2 electrical cables 1 i think was speedo on gearbox and 1 was cranskaft postion centre. surpised they would have 2 plugs close that could be mixed up.
marc1234567
Re: mk6
Postby knobby1 » Sun Mar 15, 2026 7:44 pm
marc1234567 wrote:just remembered this.
Common mistake for new players...the connectors are identical.
Lord Knobrot (Smithy)
