White Smoke
White Smoke
Postby charlie63 » Sun Mar 15, 2026 10:54 am
2012 Mk7 Transit with 2.2TDCI engine. Intermittent fault of spewing out loads of white smoke which smells of unburnt fuel. Will run perfectly then all of a sudden start smoking spewing out white smoke and I mean its that bad it must choke any motors behind me. When it smokes it seems to be underpowered but engine management light doesnt come on. It varies in length of time it smokes then stops. Not using oil or water. All the usual has been done, filters replaced etc and no fault codes stored. Thought it might be a faulty injector but this would throw up a fault code. Any help appreciated to shed some light on what it might be.
charlie63
Re: White Smoke
Postby DanMK7uk » Sun Mar 15, 2026 11:42 am
Is the DPF trying to regenerate?
DanMK7uk
Re: White Smoke
Postby T350camper » Sun Mar 15, 2026 11:47 am
Is the fuel okay? No contaminants like water or anything else you could see when you changed the filter?
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Re: White Smoke
Postby charlie63 » Sun Mar 15, 2026 12:17 pm
If there is a DPF fitted does it also require Adblue as no Adblue on this one. Am i being a bit stupid here as thought all vehicles with a DPF required Adblue. No contaminated fuel as everything was clean when the filter was changed. Even went as far a draining the tank just as a precaution.
charlie63
Re: White Smoke
Postby metalworker0 » Sun Mar 15, 2026 1:04 pm
Don't think transit had adblue until 2016
your problem is i think caused by .
1. Hole or leak in the boost pipe
2. Sticking EGR
You need to put a scanner on it to see what's going on
Re: White Smoke
Postby charlie63 » Sun Mar 15, 2026 1:23 pm
Thanks for the reply Mark. No fault codes stored but will need to put it on a proper scanner and see from there. Cheers.
charlie63
Re: White Smoke
Postby trnx » Sun Mar 15, 2026 2:51 pm
Watch ORiley DPF on youtbe.
Vapouriser, DPF partially blocked.
Coolant in exhaust. Head gasket. EGR valve, cooler.
Injectors not seated. Inlet/exhaust valves not seating. Damaged/moving cam follower. Timing chain slack.
20011 to 2014 not adblue.
Mk 7 E5 DPF RWD XLWB SRW
trnx
