metalworker0 wrote:if it does not have ABS ..I would suspect the hall sensor at the gearbox.
Deanojones wrote:metalworker0 wrote:if it does not have ABS ..I would suspect the hall sensor at the gearbox.
Thanks Mark, can you send link to purchase please, im willing to try anything… been to france did 1000 miles and its put 3000 on the clock
dumper wrote:If it’s still got original gearbox and axle maybe Ford can identify it from the reg number or has it a part number on the sensor
metalworker0 wrote:sorry cant do that too many choices of gearbox .. i don;t know what one youlve got
there you do :
1. first choice British or Turkish
2. Second choice in British .. is three gearboxes
3. and the Turkish one has three gearbox choices
There you go
You find it, since you have the info, that i don't
https://www.catcar.info/ford/?lang=en
Iv changed the sensor today and still the same, any other suggestions please im willing to try anything to get the speedo reading correctly
Dean
metalworker0 wrote:well you could go the forscan route as frag suggested .. but i have sort of got a gut feeling there is nothing digital about the set up and it is analogue.
i put into google a question:
old style hall sensor in gearbox - clocks reading double speed
read this ... if link doesn't work .. put in: old style hall sensor in gearbox, clocks reading double speed
https://www.google.com/search?q=old+sty ... nt=gws-wiz
Frag wrote:Is the bus a rwd 5 speed ?
Not the tdci with 6 speed?
Or a 5 speed originally,with a 6 speed fitted ?
If it’s all the same drivetrain as it left factory
The PCM is going to be the issue,it’s either got the wrong software completely,or the axle ratio / tyre size setting configuration is wrong for that vehicle
You need someone who knows what they are doing with a laptop.
If it was a 5 speed from factory,and someone’s converted it to 6 speed you may have same issue.
