Aircon again
Aircon again
Postby longhair » Thu Jun 25, 2026 1:53 pm
Just had my Aircon charged again as it wasn't getting cold. Local guy came out checked it for pressure before he charged the system to make sure it okay. Everything was ok so he gassed it up and it was fine but the fan was kicking in and out every few seconds which he said didn't seem right but it was working fine. He stayed for about half an hour just to make sure it was working fine. After he left I went for a quick drive and after a couple of minutes it started blowing warm again, so I came home and gave him a ring and he came straight back. He checked the pressure again and it was still correct, so it must be some sensor or something else, probably connected to the fan kicking in an out quickly. Any suggestions greatly appreciated to what may be at fault before I get a auto electrician in to have a look.
longhair
Re: Aircon again
Postby metalworker0 » Thu Jun 25, 2026 3:13 pm
You must start every new thread with the model of transit. year, engine, rwd, fwd ... you're not done this in many posts you've made .. so um! unwise to what you have.
put it in you signature .. then we don't have to ask
When you say "fan", which one are you talking about; the one in the cabin or the one in the engine bay in front of the radiator
Generally at this stage you'd be plugging forscan in and monitoring what is going on
The temperature stat in the evaporator core, what that is reading --- is it faulty causing this issue
When this switching on and off was going on, the tech should have had the gauges hooked up
Should have noted if the compressor was turning on and off with the fan.
Ralays for each fan should be checked out .. often the relays can be swapped with others that are the same and perform some other function and live in the same box.
You also have pressure switches that control things.
This problem could be complex and hard to diagnose from a remote forum
Re: Aircon again
Postby longhair » Thu Jun 25, 2026 3:35 pm
I've worked out it's the high pressure sensor. Thanks anyway.
longhair
Re: Aircon again
Postby Altransit » Thu Jun 25, 2026 5:01 pm
longhair wrote:I've worked out it's the high pressure sensor. Thanks anyway.
Keep us posted as to how you fix it please!
Aircon problems can be difficult to diagnose, and fix :)
Re: Aircon again
Postby longhair » Thu Jun 25, 2026 6:11 pm
I certainly will. Looks like you just unscrew it as it has a Schroeder valve so it doesn't lose any pressure. I will try and find a way to test it before I buy a new one. It looks like it is near the accumulator in front of the intercooler so might be a pain in the arse to get to.
By the way it's on my 2014 custom.
longhair
Re: Aircon again
Postby longhair » Sat Jun 27, 2026 9:20 am
Well now the weather has cooled down a bit, I've started trying to find the fault. I have finally found a sensor near the condenser, I don't know if it's the low or high pressure one. It has three wires going into the plug. I don't know which wires to bridge to rule the sensor out. According to what I can find out some sensors have two wires which obviously means it is just a case of bridging the two wires but this I'm not sure about.
longhair
Re: Aircon again
Postby longhair » Sat Jun 27, 2026 9:46 am
It looks like it is the high pressure one as it is on the thinner pipe.
longhair
Re: Aircon again
Postby Altransit » Sat Jun 27, 2026 10:47 am
I can't help, about the only thing I've never had a problem with, is the pressure sensors!
The most common problem I've had, is with the compressor.
Re: Aircon again
Postby longhair » Sat Jun 27, 2026 5:59 pm
Right, I have tested the relay and the pressure sensor by jumping the plug and it still doesn't kick in. As far as I understand the system only has one sensor and not two like on the older systems. Rather than being a simple switch, it is a pressure transducer that sends variable voltage to the BCM.
So the next step will be looking for any broken wires and the compressor itself, although I can't see it being that as it was working fine immediately after the regas.
longhair
Re: Aircon again
Postby metalworker0 » Sat Jun 27, 2026 6:41 pm
the other sensor is in the evaporator core inside the dash .. temperature sensor that is
i don't know if forscan will read it .. worth a try
if it does the pids will be EVAP, EVAP_TMP, or EVAPORATOR_TEMP
minus -40 means it's failed
May have a pid for commanded and actual .. if so,. they will be the ones to take note of, make more sense
Now then>
I've looked at plenty of fixing vids on this and sometime the evaporator core sensor only available with the core !
ebay
ford transit custom evaporator
from the results (not sure what i'm seeing ) looks like it comes attached to that or is that just the expansion valve ?
catcar.info - no good as i don't know what im looking at really ... cant see a sensor there
don't go buying this .. test it
Note: some customs, ecoblues, have a system on them that has an electric pump at the side of the engine that pumps coolant around the ac heater when in stop start mode, so you get heat even if engine stopped .. if this system is fitted, ive no idea on how it effects the AC system. reports here , some of these pumps have failed in the permanently on mode .. that would screw things up
for what its worth .. take note AI can be wrong .. google ai answer to the question:
Does the transit custom have heat sensor in the evaporator core
Yes, the Ford Transit Custom (and the wider Ford Transit family) is equipped with an evaporator Function of the SensorPrevents Freezing: The sensor monitors the temperature of the air leaving the evaporator core .Controls the Compressor: If the temperature drops too close to freezing (which causes the condensation on the core to freeze and block airflow), the sensor signals the Powertrain Control Module (PCM) to disengage the AC compressor clutch .Diagnostics: A faulty or erratic sensor can result in the AC failing to turn on, blowing intermittently, or shutting off entirely.
Re: Aircon again
Postby andz327 » Sat Jun 27, 2026 6:47 pm
by jumping the plug you may have fooked you fan control module that sits on the fan cowling
andz327
Re: Aircon again
Postby longhair » Sat Jun 27, 2026 8:40 pm
No I just bridged the open wire which is 5 volts to signal wire while putting the ground wire to earth Which mimicks the gas at full pressure that lets the compressor kick in.
longhair
Re: Aircon again
Postby longhair » Sun Jun 28, 2026 2:30 pm
How the hell are you supposed to get to the connector on the compressor to test it. The bloody thing is on top of the compressor with no access from the top and very limited access from underneath.It blows my mind just how difficult some simple task are perform. I am beginning to hate this van. Everything is hard work.
longhair
Re: Aircon again
Postby metalworker0 » Sun Jun 28, 2026 2:45 pm
Don't know, i don't have a custom 2.2 manual
but if you did have the manual .. the only thing these manuals are good at, is the air con system - they go into every tiny detail about it, hopeless content for all other aspects of the vehicle .. but huge detail in the Ac section. all of them are like that, the chap who wrote those sections is the only good chap they had left for the manuals writers department.
Can you get at it by removing the wheel arch liner or the front headlight?
Re: Aircon again
Postby longhair » Sun Jun 28, 2026 5:35 pm
I do have a Haynes manual and in my opinion they are sh*t towards what they used to be, printed on cheap paper with black and white photos that don't show the details like they used to when they were in colour.
The compressor is at the back of the engine block at the side of the chassis leg. I've given up trying to access it. I'm going to get plugged in and see if the fault has hopefully stored a code.
longhair
