Can only answer the pattern or genuine question .. if you buy a Pierburg one .. its one of the ones that ford puts on it . and that's a safe purchase.
StanT wrote:I would like to jump on the end of this if I may...
DId replacing the EGR fix the OPs problem?
What do people here think of the many aftermarket EGR valves that claim to be equivalent to the Ford offering for a much lower price? E.g. https://www.autodoc.co.uk/vemo/12250305
The reason I'm asking:
I have a 2013 regd. Transit 140 Sport from new. Initially brilliant but it all went downhill after the "piston burn recall" was done, although that could just be coincidence. Engine management light would come on, sometimes going into limp mode, sometimes not. It went back to Furrows under warranty, they said it was the MAFF sensor and replaced it, then fine for a couple of months until the engine management light came on again. This cycle was repeated until the warranty ran out. After that I drove around with the light on until it became an MOT fail. Friendly MOT tester cleared the fault and it stayed off long enough to get thru.
It's been off the road for a couple of years 'cos I'm pissed off with it. Now decide to try to sort it out, if only to sell it. Bought OBDLinkEX reader and downloaded FORSCAN. Cleared the fault and got thru the MOT but now I get P00BD, exactly as reported above, and it goes into limp mode every time I go over 40mph so I can no longer ignore it. With the EGR unplugged it doesn't go into limp mode and it runs fine (apart from the light on the dash). I've had the EGR valve off and cleaned it; wasn't particularly dirty - it's only done 23k miles.
I have absolutely no faith that the Ford dealer can fix it so it's down to me. What is the advice of the experts here? Replace bits of the emission control system until it works? Start with EGR or MAFF? Pattern or genuine?
tranmx2 wrote:P00BD dtc 2013 transit is - into g search - get AI result.
StanT wrote:That should have been IATS2 above.
Unplugged the sensor at the intercooler, FORSCAN read IATS2 and ACT = 20 C, which I guess is some sort of default value.
Removed the sensor and measured the resistance at room temperature = 520 ohm. Dropping into near boiling water made no difference, so I guess it's not working.
New one should be here Friday. Fingers crossed.
This is the forum post I picked up on, although it is talking about Transit Custom (Mk8?). Mines one of the last Mk7s.
https://fordtransit.org/forum/viewtopic.php?t=202379
Users browsing this forum: chprintz
