by aplcomms » Sun Jun 09, 2024 6:49 pm
My son has a 2013 Transit Custom. It recently developed a fault and gave the P00DB DTC. The DTC suggests that the MAF is faulty.
When analysing using Forscan, the Mass Airflow (MAF) and the Intake Air Temperature (IAT) appeared to be correct suggesting the combined MAF and IAT sensor on the Air Filter box were OK.
However, the Intake Air Temperature Sensor 2 (IATS2) was showing 126C even when the engine was cold. This sensor is located near the output of the Intercooler underneath the vehicle.
I had seen many YouTube videos and read many posts about this so I bought a new intercooler temperature sensor. The resistance at room temperature was around 11,000 ohms.
I connected my laptop with Forscan and IATS2 was at 126C. I unplugged the connector from the Intercooler sensor and temporarily fitted the new sensor to it. The IATS2 temperature was then 14C which was the same as the IAT. I removed the temperature sensor from the intercooler and fitted the new one and the IATS2 temperature behaved normally when the engine was started.
I measured the resistance of the old sensor and it was 519 ohms which is low and is a credible reading, but not a short circuit.
My conclusion is that these sensors go faulty with a low resistance but is not reported as faulty by the PCM. Instead the PCM incorrectly decides that the MAF is faulty, causing many to change the expensive MAF when there is no need to so so.
I hope that this helps.
