automatic transmission
Postby brakeman53 » Sat Aug 08, 2026 6:20 pm
Hi can any one help is the A4LD-e gearbox the same internals as the A4LD and just out side bolt on components different and could i fit mechanical kick down and vacuum parts to A4LD-e :?:
brakeman53
Re: automatic transmission
Postby metalworker0 » Sat Aug 08, 2026 8:21 pm
Does this help you .. it's a ford ranger .. but you are unlikely to get anything else on the subject
https://www.therangerstation.com/tech/f ... #gsc.tab=0
Link a bit hit and miss , when the link gets there .. sometimes fails, sometimes ok 1 min later
i went looking for info a while back and it was the best i could find .
Postby brakeman53 » Sun Aug 09, 2026 11:11 am
Thanks for the link very help full as i want to try and keep as a automatic cheers Rob
brakeman53
