MK5 Transit 2.5 Turbo Diesel Water Pump
Postby Peterr » Thu Aug 20, 2026 5:02 pm
Today I decided to replace the water pump with a new one. Not sure if was necessary but since I already have a new one and general advice is to go ahead and change it while the timing belt is off.
The old paper gasket was baked onto the engine side and would not scrape of easily. Heating up with a pipe lighter helped it scrape off easily. Absolutely do not use a steel brush as tempting as it maybe, it will scour grooved onto the aluminum.
Nicely cleaned up!
New pump!
Keep on Transiting !
Peterr
Re: MK5 Transit 2.5 Turbo Diesel Water Pump
Postby metalworker0 » Thu Aug 20, 2026 5:27 pm
That fan clutch , looks well passed its best .. get that replaced while you are there .
There is a special tungsten tipped tool for the gasket scrapping .. its all about getting the right angle so you do not gouge the aluminium ..
never seen anyone use a lighter .. seems to have worked so all is good
Postby Peterr » Thu Aug 20, 2026 5:29 pm
Thanks Mark, will do! All belts will be changed. Well past their due date!
Peterr
Postby Peterr » Thu Aug 20, 2026 5:34 pm
I wasn’t able to get the fan clutch off. The difficult to reach nut behind is seized. I Assume it’s a right-handed thread. Was wondering why do you think it should be changed, excessive axel free play? It’s probably never been changed in over 300k km.
Peterr
Postby metalworker0 » Thu Aug 20, 2026 5:43 pm
Mostly they are left handed .. and have be cracked loose with a chisel
Some times they do this to the nut to show its left handed - see the little gouges on the apex of the hexagon
https://boltin.com.au/wp-content/upload ... 7-18-2.png
Postby metalworker0 » Thu Aug 20, 2026 6:04 pm
just done some delving and they are right hand thread
Postby Peterr » Thu Aug 20, 2026 6:07 pm
Thanks for correcting that, would be a mess if I forced it the wrong way! Gets confusing at times, little changes between models and years and what we thought we know no longer applies! Just sent you a PM.
Peterr
Postby cherniy_chack » Thu Aug 27, 2026 5:01 pm
The nut on the heat-shrink coupling has a right-hand thread.
It's usually impossible to unscrew it after years of use. In such cases, I cut the coupling with a grinder and a thin cutting disc and trim off one edge of the nut. If this slightly damages the threads, it doesn't matter.
After trimming off the edge of the nut, it comes off without any problem.
cherniy_chack
Postby V184 » Sat Aug 29, 2026 10:00 pm
Peterr wrote:Thanks for correcting that, would be a mess if I forced it the wrong way! Gets confusing at times, little changes between models and years and what we thought we know no longer applies! Just sent you a PM.
Best to remove it with the fan belt on (tensioned). I used to use a steel bar, strike with a hammer soon moves. Turbo hubs were prone to exiting through the radiator :shock: so best to check condition :wink:
Nice job on the waterpump 8) We used to try and get them off hot and normally the gasket would stick to the pump
V184
Postby Peterr » Sun Aug 30, 2026 7:14 am
Thanks for the tips. Unfortunately couldn’t warm the engine. Still busy installing the Otosan pump ( Bosch clone).
There is a little wiggle on the fan clutch. There’s 300k km on the engine. Probably needs to be changed. Does it have replaceable bearings? Or must I order a new one?
Peterr
Postby metalworker0 » Sun Aug 30, 2026 2:08 pm
not repairable .. only replaceable
careful with choice, only go for well know brand names
Postby bruce.edlin3001 » Mon Oct 19, 2026 7:39 am
Take the fan clutch off and put an electric fan on, save fuel and less pressure on the bearings
Sent from my SM-A156E using Tapatalk
bruce.edlin3001
Postby Peterr » Mon Oct 19, 2026 9:58 am
Thanks, I just so happen to have a recovered electric radiator fan. So can I simply rig it up to the alternator charging line to be on all the time while the engine is running or where do I need to put a thermostat to turn it on? At what temperature setting ?
How would it save fuel? The alternator belt still runs over the fan pulley. Less air resistance with fan removed?
Extra load on the alternator to drive the electric fan also uses slightly more engine power thus more fuel. Case of false economy?
Peterr
Postby metalworker0 » Mon Oct 19, 2026 5:50 pm
Well if you were to put on it a proper electric fan conversion made by someone like Kenlowe. the kit would come with a sensor probe that you insert under the top radiator hose clamp into the coolant
you can see the probe in this bunch of wiring at the top of the picture for kenlowe
https://rimmerbros.com/ItemImages/Large/115210-Zoom.jpg
looking around ---
or maybe this is better .switch kit.. comes with a switched temperature dial that you can set it up with
https://www.ebay.co.uk/itm/376569737738?
hope this helps
Postby Peterr » Mon Oct 19, 2026 6:12 pm
Thanks Mark for the info! Interesting setup. I have enough electronic knowledge to build my own circuit from these examples.
Peterr
