RWD Half Shaft/Axle Wont Go All The Way In
Re: RWD Half Shaft/Axle Wont Go All The Way In
Postby PWRR-TRANSIT » Wed Sep 16, 2026 11:01 am
FIXED!!
Turns out i was just being a useless idiot. Happens more often than you think :D
Because this side had a new hub and bearings. it was stiffer to rotate once fitted on the shaft. This meant when it came to turning the axle to get the splines to line up, it was very hard to get a micro adjustment due to the extra stiffness of new bearings and races etc. The other side only needed a slight wiggle and it slammed in. It was easier to wiggle because it was the old bearings which are worn in.
All i had to do firmly grip the flange and the hub in a way that let me rotate it 0.5mm and it immediately went in. A micro adjustment was all that was needed! I was obviously being too clunky with the wiggling before!
Thanks anyway to everyone who tried to help. I'll see myself out :D
2007 2.4L RWD 350 MWB SEMI HIGH TOP LOVE MACHINE.
Before you criticize someone, you should walk a mile in their shoes. That way when you criticize them, you are a mile away from them and you have their shoes.
PWRR-TRANSIT
Postby knobby1 » Wed Sep 16, 2026 7:44 pm
PWRR-TRANSIT wrote:FIXED!!
Either way...Result..! :mrgreen:
My Father used to tell me..."He who makes no mistakes....makes nothing"..!
Lord Knobrot (Smithy)
Postby andz327 » Thu Sep 17, 2026 12:26 pm
Result your one of the few thats came back on to update the result.....mind you a tight new wheelbearing doesn't quite sound healthy nice one bud
andz327
Postby dumper » Thu Sep 17, 2026 1:06 pm
Did you lubricate the bearing when you fitted it
