What did you do to your mk 3/4/5 today.
Re: What did you do to your mk 3/4/5 today.
Postby Peterr » Tue Sep 01, 2026 8:46 am
Peterr wrote:I can’t figure out how its used….
Ok, on this bolt on the top of the pump:
Keep on Transiting !
Peterr
Postby gotgcoalman » Tue Sep 29, 2026 6:19 pm
Ordered a couple of tyres,so attacked the rims with mr wire brush.
The idea was to tart them up a bit .
Too bloody quiet :shock:
gotgcoalman
Postby gotgcoalman » Sat Oct 03, 2026 6:18 pm
Took all afternoon to do an oil change.
Fook it was mining
gotgcoalman
Postby gotgcoalman » Sun Oct 04, 2026 1:18 pm
Decided to do the valve clearance.
Wish I hadn't bothered.
Although the rocker cover was leaking so it needed fixing.
What a headache.
Stupid pipe has snapped.
gotgcoalman
Postby gotgcoalman » Sun Oct 04, 2026 4:38 pm
1/4 of a gazillion miles and tnt the nannas aren't too fouled.
gotgcoalman
Postby Peterr » Mon Oct 05, 2026 9:41 am
I have mine blanked off. I cut a “gasket” from an aluminum can and used a hole punch to cut out the holes for the bolts. After cutting open an aluminum can, flatten it out and trace the shape and hole positions. First punch out the holes then cut out the shape with shears.
My tube wasn’t broken so your going to have to find a way to block off the tube too. Probably cut it shorter then use a metal cap to close it or a metal plug. Or flatten the end in a vise and fold it over.
Peterr
Postby gotgcoalman » Mon Oct 05, 2026 1:31 pm
Yep mines blanked at the top with a plate I made years ago.
Cut the head off and M10 coach/roof bolt and welded it to the manifold to block the hole.
Added some pipe (diesel heater exhaust) to make it a very tight fit.
I'm a better illusionist than David Copperfield
gotgcoalman
Postby gotgcoalman » Thu Oct 08, 2026 4:58 pm
Bloody ford.
gotgcoalman
Postby Peterr » Thu Oct 08, 2026 5:50 pm
Looks like a pass!
Fortunately here in Italy it’s only every two years and they’re not too strict.
When living in Holland it was a bloody nightmare every year welding up undercarriage rusty holes. They would go under the chassis shoving a screwdriver up to see if it was solid punching holes where there was rust.
Peterr
