fabcal wrote:They told me new would cost around 2500 EUR...
fabcal wrote:Thanks
I needed to transport some equipment so I drove the van anyway. Towed a trailer for about 300 km with total weight of approx 1000 kg and had around 400 kg inside the van. Prior to loading the van I drove about 100 km. During these 100 km there was a clear hammering sound from the engine at any load but after a while it disappeared at normal load. I measured the cylinder balance before loading and the max value measured had increased from around 6 to around 8.
Are the cylinder balance values due exclusively to the injectors or could there be another cause? Not keen on spending several 100 EUR again unless I'm almost sure it will fix the engine problems. Any other checks I should do before changing the injectors again?
fabcal wrote:I guess the balance numbers (in mg btw) are all I need to diagnose bad injectors? Not necessary to perform a leak-off test or those pressure tests I've seen where they disconnect the injector for a second.
fabcal wrote:No progress since last post.
Is there any kind of service on the injectors I can do on my own? Thinking it would be worth a try.
metalworker0 wrote:note that my petrol injector runs at 27 psi .. not 36,000 psiall the best.mark
