Heavy black smoke from exhaust, oil leaking and EGR error
Re: Heavy black smoke from exhaust, oil leaking and EGR erro
Postby knobby1 » Sun Oct 18, 2026 8:00 pm
metalworker0 wrote:well you are going to have to do some maths then
i cant understand why everyone has missing pids on forscan
the egr stepper motor position
there are 200 steps in 360 degrees
your motor only turns 90 degrees to fully open or fully close the flap
so 90 degrees is 100 percent or 50 steps
Mk7 EGR valve doesn't have a "flap"...it has a valve, not dissimilar to a normal engine inlet or exhaust valve in shape. So your 90 degrees or 50 steps to 100% means nothing.
Lord Knobrot (Smithy).
Postby metalworker0 » Sun Oct 18, 2026 8:13 pm
ok then .. that is out of the way.
i'm totally wrong on this one , but may apply top other egrs
so steps in this instance means nothing unless you could have it open connected up and observe what going on
you are going to have to find egr actual percentage
maybe this is never given on this type of EGR
