mine is in the same place as the existing battery but at the other side!!spondootre wrote:Where would the other battery go? under the drives seat?
spondootre wrote:I might phone fords and ask the question on how much........then after i've picked myself up off the floor and reset the phone i'll go the scrappy and have a look!!
Where would the other battery go? under the drives seat? If I can't find an upgrade that'll go I suppose I could go down the split charging route.
Malc
MrMPuk wrote:If you buy another battery tray it will just bolt straight in, only thing is i'm not sure if they are handed!
