Transit Engine Conversion
Postby Bryan » Fri Oct 19, 2007 8:55 pm
My Transit luton has been off the road for about 6 months now awaiting a second hand turbo unit but to no avail. They seem to be like hen's teeth. So I've been thinking about doing an engine conversion on it instead to something more reliable and modern.
I would love to convert it to a big thirsty V8 diesel american engine but they're far too expensive so I was thinking about the Vauxhall Omega 2.5TD engne and gearbox - the BMW 6 cylinder unit. The Omega is RWD so the engine and box are already in the correct position but it's a question whether or not the engine mounts will match up to the Transit ones - I'm not too worried about the gearbox mount as it can be easily modified.
I don't want to go down the road of a sprinter engine as they're far too expensive. The reason I was thinking of an Omega is because they're quite popular and I could pick up a whole car for the engine/box and wiring loom for pretty cheap.
Is anyone familiar with this engine and box to give me an idea whether this idea would work?
Bryan
Re: Transit Engine Conversion
Postby AndyG » Fri Oct 19, 2007 9:23 pm
Those BMW diesel engines are extremely fussy on getting their oil changed on time, so make sure you pick a good one :!:
Next question I have for you, is, have you measured correctly :?: As the engine seems rather long to fit in there with the radiator :roll: :D
Postby Bryan » Fri Oct 19, 2007 9:26 pm
I don't know I haven't actually seen an Omega engine in person - just the only engine I could think of that would be cheap to get my hands on a complete car for all the parts needed.
I'd also thought about an Iveco lump but they're mega money for the engine alone.
At the end of the day a new turbo will set me back £350-400 so for a little more I could have a decent modern engine if it will fit, that is.
Bryan
Postby djswampy » Fri Oct 19, 2007 11:52 pm
Could you not convert it to 76ps to get you going again until a turbo arrives, or do a guy88?
djswampy
Postby bazw » Sat Oct 20, 2007 2:52 am
i could fit the omega engine into my sprinter but i dont think the tranny has enough room on the drivers side
remember it is a quad cam so the heads are very wide
i did think about this swop and could not get an engine box and harness for less than £300
mind you i did think about a jag V12 swop as i had one at the start of frankensprinter , all it needed was 2 6"X6"X3" boxes welding into the fire wall to fit it as the sprinter is made to take a 5 pot engine
the guys who have the cossy V6 will give you a good idea of how much room there is and i think the cossy is 2" narrower than the omega engine
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby OxtonyxO » Sat Oct 20, 2007 9:01 am
if the omega engine is 2" wider than the cossie 6 pot then you will need to do a lot of work on the bulkhead also you may find that where the clutch cable goes through the bulkhead will be in the way
OxtonyxO
Postby Mike400 » Thu Dec 27, 2007 11:45 am
I think you are missing the point - he wants to fit an Omega TD engine which is a straight 6 not a V6. Either way its probably too long.
Besides the gear ratios in the Omega box wont be that well suited to a van?
Mike400
Postby Guy88 » Thu Dec 27, 2007 12:22 pm
i dont think a straight 6 has a chance. without serious bulkhead mods
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby intransit89 » Sat Dec 29, 2007 4:48 am
Guy88 wrote:i dont think a straight 6 has a chance. without serious bulkhead mods
it would be same size as the tranny engine but half the transit engine again and if you get me it will be as long as the tranny engine but maybe with a other 1/2 of the engine aslong long as you will have to redo the gear box hole more backwards and the bulkhead behind the engine as guy says i know its about 1/2 longer of a transit engine as we use to have a stright 6 carlton engine and that was 1/2 longer then a transit engine hope this helps as it has 2 more cylinders to add :wink:
intransit89
Postby MRspivvy » Wed Jan 02, 2008 3:19 pm
if you can find one, an audi 5 cylinder diesel? you can convert these to RWD using a volvo 740/60 diesel gearbox
MRspivvy
