Sticky problem?
Sticky problem?
Postby fat-freddys-cat » Fri Dec 23, 2005 7:27 pm
Anybody know of any effective ways to remove the sticky mess left behind after removing vinyl stickers from bodywork?
Always used WD40 before but this time it's not workin'
fat-freddys-cat
Postby 100ps_drw_hicube » Fri Dec 23, 2005 7:34 pm
on my old van the paint work was very dull and the old signwriting showed up badly so i got a tin of rubbing compound 3 whole days later i had mint looking paintwork looked better than a respray it is hard work but well worth it in the end :D also works well on white fiberglass roofs on hi tops :)
100ps_drw_hicube
Transit Abuser!!
Postby Luke » Fri Dec 23, 2005 7:40 pm
T-cut! :D or is that what rubbing compound is? :?
Postby madmark » Fri Dec 23, 2005 7:42 pm
petrol, or thinners! :)
Postby 100ps_drw_hicube » Fri Dec 23, 2005 7:46 pm
madmark wrote:petrol, or thinners! :)
are you a millionaire??? :shock: i can barely afford to put fuel in the van let alone wiping it all over the van :D
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Fri Dec 23, 2005 7:49 pm
rubbing compound is good but is hard to get hold of t -cut works but requires a lot more elbow grease than rubbing compound last tin of rubbing compound i got was from part co they are also the only place in my area that sells thinners :?
100ps_drw_hicube
Transit Abuser!!
sticky problem
Postby Neil » Fri Dec 23, 2005 8:27 pm
hair dryer to heat up and scrape off as much as you can then use cellulose thinners
Neil v6
Neil
Postby rover » Fri Dec 23, 2005 9:28 pm
Go the Chemist, and get some 'Meths' (admit to being an Alcaholic if you have to :lol: ), its cheap as chips and will get rid of the 'sticky stuff', just dont leave the top off or it will be gone next time you look round!
Rover.
rover
Postby bazw » Fri Dec 23, 2005 9:41 pm
acetone is good for this but cold on the hands in winter :D
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby Nighthawk » Fri Dec 23, 2005 10:23 pm
Tar and glue remover has always worked well.
Find a company that sells to the car valeting trade and buy a gallon off them, :)
Nighthawk
Postby gemini » Fri Dec 23, 2005 11:14 pm
white spirits works best
gemini
Postby gazza » Sat Dec 24, 2005 2:00 am
lighter fluid is another good one
gazza
Postby FredTransit » Sat Dec 24, 2005 2:16 am
Our body man has some magic wipes, he used them where the amby's old insignia was, they are magic, but he didn't tell me what brand they are, can find out later for you.
FredTransit
Mk2 Trannyist
Postby Gunslinger » Sat Dec 24, 2005 4:41 pm
a company called Kleeneze do some stuff called "sticky stuff remover" i always found it very good for just about anything like this right through to removing the residue left by sticky plasters on your fingers etc
Gunslinger
Petrol works!
Postby fat-freddys-cat » Sat Dec 24, 2005 5:39 pm
Cheers, tried petrol as it was all I had to hand, worked a treat no marks not even from sun bleaching, stickers must have not long been on there. Only needed a couple o caps full and used dish washing sponge.
All the best folks, have a good un :wink:
fat-freddys-cat
