Twin exhaust
Twin exhaust
Postby Andrew-v4 » Tue Dec 27, 2005 12:46 am
Just wondering if there are anyone who has put a twin exhausts out the back of there van :?:
Fancy doing this but need a couple of pictures to get an idea.
Andrew-v4
twin exhausts
Postby Neil » Tue Dec 27, 2005 10:31 am
ive got one down either side
Neil v6
Neil
Postby Gunslinger » Tue Dec 27, 2005 12:00 pm
i will have 2 outlets on the drivers side of my van just infront of the rear wheels when i build my exhaust, but thats only because the chrome oval end sections i have are too small to use on their own so i will use both of them together :)
Gunslinger
Postby jay » Tue Dec 27, 2005 12:31 pm
yeah i thought of this before..twin pipes looks nice...even on a stock van.
mk1 connect tourneo
jay
Postby Gunslinger » Tue Dec 27, 2005 12:43 pm
well the idea was to keep as much stock as possible,although i am gonna change a couple of things
1) wont be as close to the prop (i'll add a section to the cross pipe)
2) the round box in the standard config will be a stainless one, but other than that the middle section with the boxes will be standard dimensions and front fitting just cut shorter at the rear, so easy to replace
3) my home built section at the end (90 degree bend and one into 2 splitter will slide onto the end of original shortened middle/box section for easy replacement)
4) no fooking way is it going over the rear axle and all that crap again :P
Gunslinger
Postby jay » Tue Dec 27, 2005 12:56 pm
yeah .just get rid of the rear bit over the axle...just have the stock exhaust silencer bit.but fit your own side exit bit...i like that idea.you got me thinking now.........side exit on mine.....saves having a exhaust ring on the garage door from the rear exhaust... :D
mk1 connect tourneo
jay
Postby madmark » Tue Dec 27, 2005 1:17 pm
personaly i dont think a transit look write if it hasnt got the exhaust out the back, :? allthuogh i will probly have to have a side exit on the mk1 ! :?
Postby jay » Tue Dec 27, 2005 1:25 pm
least with a side exit you can see how much black.white .blue smoke you have coming out.. :D (choose which colour you have..)
mk1 connect tourneo
jay
Postby Gunslinger » Tue Dec 27, 2005 2:00 pm
LOL, the only downside, is that you lose the space for a second fuel tank, i actually considered redisigning mine and kicing it out early to leave the space for that :)
Gunslinger
Postby madmark » Tue Dec 27, 2005 2:16 pm
i am still running the standard v4 system on the mk1 but the downpipes have been moded and and i think its not letting enouph gases thruogh, so might have to have a system made , or oneday find the original v6 transit down pipes! :?
twin exhausts
Postby Neil » Tue Dec 27, 2005 3:06 pm
madmark wrote:i am still running the standard v4 system on the mk1 but the downpipes have been moded and and i think its not letting enouph gases thruogh, so might have to have a system made , or oneday find the original v6 transit down pipes! :?
v4 system will restrict the flow mark i am also considering removal of sidepipes for a out back system but i have to say that the sills are perfect maybe because they are always hot when runnin also i may have a steel pair of downpipes
Neil v6
Neil
Postby Valsheda » Tue Dec 27, 2005 4:28 pm
HIYA ANDREW , I HAVE A TWIN TRIM ON THE BACK OF MY POWERFLOW SYSTEM , THE JOIN OF THE TRIM SITS FAR ENOUGH BACK TO GIVE THE IMPRESSION OF TWIN PIPES
Valsheda
Top Tourneo Owner
Postby Gunslinger » Tue Dec 27, 2005 7:02 pm
thats something like what i will be aiming for, only on the side and angled downward slightly, maybe not sticking out that far either, keep it kind of subtle
Gunslinger
Postby Andrew-v4 » Tue Dec 27, 2005 9:09 pm
sorry guys i ment one each side :oops:
Yours looks nice mark but want it to look standard :?
Andrew-v4
Postby Luke » Tue Dec 27, 2005 10:42 pm
what like this :?:
Return to Transit Talk
