oil leak
oil leak
Postby belly » Fri Feb 15, 2008 10:56 am
Hi my o5 connect seems to have started to leak a little oil only a slight drip :evil: it seems to be around the sump gasket but tbh ive not had any time to check it out properly :roll: is there a common fault maybe around that area ? its beneath where all the pulleys and gubbins are! the van is on 24k now and its a t230 lx tdci 90ps would this be a warrenty job? as i think its warrenty is up on the 1st of march! plus jan and feb are always tight months fo me due too inland revenue :( so im hoping this is a warrenty thingy! in the meantime im checking the oil religiously :wink:
belly
Kaiser Chief
Re: oil leak
Postby Nighthawk » Sat Feb 16, 2008 6:38 pm
I'd have a good look at it, the filter can leak a little as the seal ages.
The sumps are usually OK as they use a sealant on the joint and not a gasket.
Crank seals and fuel pump gear seals can also leak, but they aren't that common tbh.
Transit.........Job done
Nighthawk
Re: oil leak
Postby coconut » Sat Feb 16, 2008 9:47 pm
I'd go with the crank seal or pump gear, but I have done quite a few engine ladder frame gaskets.
Should be warranty, unless anything has damaged it :shock:
coconut
Ford Technician
Re: oil leak
Postby belly » Sun Feb 17, 2008 6:40 pm
cheers guys the top bannanas as usual 8) just got back from working away so will have a good look tomoz and get it in to the dealers :)
belly
Kaiser Chief
Re: oil leak
Postby belly » Tue Feb 19, 2008 6:44 pm
just a update hendys have got the van at the mo! rang up today and the bloke on the service desk told me that the gearbox was out :shock: and that it was the sump gasket and rear oil seal so theyve got to keep it overnight! which isnt a prob as long as its all done ok :) how does this sound to you guys? i never trust what the service desk say cos there not the lads doing the work :) so far though theyve been very helpfull and understanding that i need the van 8)
belly
Kaiser Chief
Re: oil leak
Postby coconut » Wed Feb 20, 2008 12:20 am
Yep, sounds about right :D you have to take the gearbox out to do the rear crank seal, so nothing to worry about :lol: :lol:
coconut
Ford Technician
Re: oil leak
Postby belly » Thu Feb 21, 2008 7:34 pm
got my van back today all done and was completely free all warrenty which was nice 8) i think i was expecting hassle as the warrenty runs out at the end of the month :roll: the dealer was extremely helpfull they rang me twice to let me know how it was all going and ive got the van back all cleaned and steamed off underside too so all good cheers for the help guys :mrgreen:
belly
Kaiser Chief
