alanwh wrote:Some piccies for you,
Theres a pic of the so called filter conversion. Apparently the garage said the originals were prone to cracking and letting air in ??!!
I blocked off the EGR just before alloy manifold in the pic.
when you was timing up the pump and the holes ended up at the right end of the slots would this mean that the ''timing pin'' on pump did not lined up when you it was finaly set ,,but was slightly advanced ?? converted my td today and i made the mistake of setting pulley on pump at right end of slot before i fitted it ,,then lined pins up ,,, i think i have to advance 1 tooth do you follow mealanwh wrote:Went to collect the pump from Burnley on Friday morning and started the job in the afternoon.
First job was to remove the PATS, then a slight ignition modification which was thankfully much easier than I had anticipated. I mounted the pump with the three studs at the front and two studs on the rear bracket to block mounting. I had been given advice to use the Bosch injector pipes but the original Epic pipes fitted well, with only little careful bending at the fuel pump union ends required. A trip to the local scrappers was required as I hadn’t accounted for the epic and bosch pump fuel unions been different. The Bosch is a banjo fitting, the epic is a male screw in nipple.
I blanked off the EGR by undoing the union between the valve and the inlet manifold, removing the gasket and using it as a template to cut out blanking plate from a piece of thin Aluminium.
I wasn’t sure what to do about the throttle butterfly located just in the inlet manifold after the Red flexi -connector. It was sprung in the open position so to make sure it stayed there without the help of the Epic, I fixed it in place with the aid of a self tapper.
Next job was to fit the new belt and tensioner, making sure that there was full tension on the belt especially between cam and crank pulley, which had a tendency to sag a tooth too slack. I achieved good tension between the two without scuffing knuckles by rotating the crank half a tooth enough to get on the belt then rotating the crank back and popping the timing pin back in. The Pump Pulley was positioned with the timing pin in place and the pulley bolts in the middle of the elongated slots allowing me a few degrees of retard and advance to play with.
I then fitted the manual throttle pedal, cable and linkage to the pump.
Start up was a twenty minute affair. Systematically cracking the feed to the injectors, starting, bleeding, tightening and then repeating. The van started with a lot of smoke of unburned diesel after a few attempts. I ran for no more that 10 secs then switched off. I then started to adjust the pump by a degree at a time. I achieved this by slackening off the pump to pulley bolts then rotating the shaft of the pump clockwise. I wanted to achieve a balance of quick startup from cold with least smoke, good idle and less soot on throttle which after a few attempts was achieved with the bolts being at the very right end of the slots. I left the van overnight, as I wanted to check it would start at this setting from first cold. She started first turn of the key the next morning so I torque and thread-locked everything into place. Timing cover and belts were replaced, new coolant added and the radiator mounted.
I turned up the pump fueling by a turn and a half and took her out for a run, wow what a revelation, the mid range torque is awesome, she pulled up the A61 into Birdwell in 5th from 30 and gained all the way up the hill to a good 60MPH. Down the Parkway at 80 MPH was a breeze with more to spare. Personally I don’t believe its geared to go much above this speed so that was the limit… The Temp guage even works !!
Back at the ranch I noticed she was smoking quite a lot just before full boost (and on back off) until the turbo supplied enough air to burn off the extra fuel. I backed off the fuelling until the smoke was under control.
The Bro. Is going to be using the van for the next few weeks until his LT is back from the dealers so fingers crossed and wish him luck.
And lets hope the smiley keeps on smiling
Will keep you posted !
alanwh wrote:Forgot to say... The pump number for future reference is 0460-414-145 686-2
In the last month or so that Ive spoke to quite a few people who have installed and run any old banana pump on these conversions to sell them on. A guy from Riverside Auto's who services old smileys all day says he has even seen conversions coming in with the little pumps on them.
Not wanting a bodge I have installed this pump as best advice seems to suggest the 145/146 686 is the only pump up to the fuelling requirements of the 100PS.
and this one works well,
Anyone done a successful conversion with any other pumps ?
