Emergency! Graffiti on my Mark 6!
Postby Cooter » Fri Apr 04, 2008 1:20 pm
Is there a cheap way to getting rid of the lovely fresh graffit thats been so kindly left on the side of my gleaming white Mark 6? All done in a kind of permanent thick black paint/marker pen.
The little f***! And I live out in the sticks in the countryside!
:cry:
Always smileying!
Cooter
Re: Emergency! Graffiti on my Mark 6!
Postby mk2transitv8 » Fri Apr 04, 2008 1:36 pm
Petrol or thinners will do the job
mk2transitv8
Postby Cooter » Fri Apr 04, 2008 1:52 pm
Will that not effect the bodywork paint though?
Always smileying!
Cooter
Postby tinkadill » Fri Apr 04, 2008 2:03 pm
try a litttlke bit on an inconspico=uous spot first, but petrol should be ok as it doesent affect the paint when you splash some down the side of the car filling up?
a bit of T cut may also help!
Transit 330 swb Van semi high top 2.4 diesel 53 plate
tinkadill
Postby FredTransit » Fri Apr 04, 2008 3:15 pm
If it's paint, thinners will get it off, or petrol lighter fluid. You will be less lucky with marker pen, as it sinks in. Try a bit of T cut on it, or rubbing compound.
FredTransit
Mk2 Trannyist
Postby doughythevanman » Fri Apr 04, 2008 3:30 pm
I would go with compound.
P reg SWB Semi high top
S reg LWB 190 Semi high top
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby Cooter » Fri Apr 04, 2008 3:45 pm
I've tried white spirit and tcut, neither worked however the tcut did fade it slightly. I'm gutted, only had this van a week :cry:
It is a marker pen effort, in which case where would I find this compound stuff?
Always smileying!
Cooter
Postby doughythevanman » Fri Apr 04, 2008 3:48 pm
go with a fine grit compound and should do the trick.
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby Guy88 » Fri Apr 04, 2008 8:05 pm
Thinners will f**k the paint, id compund it with G3 then a real good quality wax
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Fri Apr 04, 2008 8:38 pm
you can get rid of perminant marker pen by drawing over it with a non-perminant marker pen then just wipe off :D
Postby lostpaul67 » Fri Apr 04, 2008 8:48 pm
Try nail varnish remover and a soft cloth, should remove it all with no paint damage.
T260/130ps Glx
My Mk7 Ford Transit161k miles
lostpaul67
GLX Posse - Founder member
Postby motorwise » Fri Apr 04, 2008 9:34 pm
as Fred says marker pen sinks into the paint so go carefully - try Luke's dry wipe pen method
http://www.motorwise.net
motorwise
Postby lostpaul67 » Fri Apr 04, 2008 10:06 pm
T260/130ps Glx
lostpaul67
Postby Cooter » Sat Apr 05, 2008 3:41 pm
lostpaul67 you my friend saved the day. Nail polish remover was the tool needed along with gentle rubbing, its surprising how potent that stuff is! Anyway, graffiti has now totally gone, however paintwork is a tiny bit patchy here and there so not perfect but hardly noticeable.
Thanks all for the concern :)
Always smileying!
Cooter
Postby lostpaul67 » Sun Apr 06, 2008 3:43 pm
Cooter wrote:lostpaul67 you my friend saved the day. Nail polish remover was the tool needed along with gentle rubbing, its surprising how potent that stuff is! Anyway, graffiti has now totally gone, however paintwork is a tiny bit patchy here and there so not perfect but hardly noticeable.
Your welcome mate thats what we are all here for :) :)
T260/130ps Glx
lostpaul67
Return to Transit Talk
