AlanN wrote:Yes, nice welding, have you given it89 any lessons yets
yeah the MK6 box is the DOHC MT75 the starter is on the o/s the cossy on has it on the n/s from a quick check today the cossy one will fit the mounts but i think the flywheel is smaller - certanly on the DOHC it's too far meshed into itrover wrote:Are you mating the Mk6 gearbox to the Cossie engine? If so then I dont see why you can use a Sierra 1.8 cvh starter, thats what they use with Zetec conversions, flywheel too![]()
Rover.
Luke wrote:thanks for the kind wordsi was as crap as int once
only at welding tho
practice makes perfect
Luke wrote:yeah the MK6 box is the DOHC MT75 the starter is on the o/s the cossy on has it on the n/s from a quick check today the cossy one will fit the mounts but i think the flywheel is smaller - certanly on the DOHC it's too far meshed into itrover wrote:Are you mating the Mk6 gearbox to the Cossie engine? If so then I dont see why you can use a Sierra 1.8 cvh starter, thats what they use with Zetec conversions, flywheel too![]()
Rover.![]()
the CVH flywheel i assume will fit the zetec no probs as they are the same block but i dont think it will fit the cossy/pinto crankcertanly worth a try especially if the starter itself will mate with the cossy flywheel
when i get the cossy out i can use the plate that goes between the engine and bellhousing form both engines lay one on top of the other see what the difference is - if any
thats the onetransitgeoff wrote:scuttle
