Disconnected Wire (help)
Postby MrMPuk » Mon Jan 23, 2006 3:12 pm
Postby MrMPuk » Mon Jan 23, 2006 4:22 pm
These are the pictures that Aztran sent to me!
Postby Aztran » Mon Jan 23, 2006 4:34 pm
Nice1..............not the best pics but that should give u sum idea.....
2000 x, new style Transit 350!
Aztran
Postby MrMPuk » Mon Jan 23, 2006 4:40 pm
With the rubber boot it looks like it could be off the alternator or starter?
Postby 100ps_drw_hicube » Mon Jan 23, 2006 4:47 pm
right might of solved this one mine is a td same basic engine tho it has exactly that kinda plug/wire connecting up into the block right next to the oil feed hose for the vac pump have a look there and see what it is like i will get a piccy for you to see
100ps_drw_hicube
Transit Abuser!!
Postby 100ps_drw_hicube » Mon Jan 23, 2006 4:52 pm
am i right in thinking this is something to do with oil pressure switch???
100ps_drw_hicube
Transit Abuser!!
Postby Aztran » Mon Jan 23, 2006 4:52 pm
Cool cool if u could please, thanks
Aztran
Postby Aztran » Tue Jan 24, 2006 11:23 am
That looks like it but i cant see anywhere it can connect :oops:
If it was the oil pressure switch would the oil light come on, on the dash when starting? It does as normal!
Could u take that pic again but a bit further bak please? soz to b a pain!
Could the wire being disconnected cause any problems? As far as im aware the van is runnin ok...
Aztran
Postby Aztran » Tue Jan 24, 2006 11:34 am
100ps_drw_hicube wrote:am i right in thinking this is something to do with oil pressure switch???
Its not that 100%.thats in place.
Aztran
Postby FredTransit » Tue Jan 24, 2006 4:33 pm
MrMPuk wrote:It's a Mk5 Fred!
I know they def carried this on the heater control thing (two sliders for petrol, three for diesel) to the Mk3, so thought it would go on after that. I could be wrong.
FredTransit
Mk2 Trannyist
Postby Aztran » Wed Jan 25, 2006 9:48 am
Any updates please, could it be summat to do with starting? Having a bit of trouble in the morning since its come free
Aztran
Postby 100ps_drw_hicube » Wed Jan 25, 2006 9:56 am
can you trace it back to anywhere??
100ps_drw_hicube
Transit Abuser!!
Postby Aztran » Wed Jan 25, 2006 11:34 am
Just runs into a wiring loom back toward the battery......from the loom to the end, its about ten inches so it cant go far, but i cant work out where it goes.
Aztran
Postby Gunslinger » Wed Jan 25, 2006 11:36 am
that was my thought exactly, need to trace it back and see.
also i think fred asked if it had a conversion done, becasue spare wires are always a problem with conversions
2 other things
1) you said the oil light comes on normally at start, i am assuming it goes out shortly after starting .... this would indicate that it is not the oil switch
2) i assume you meant you were having trouble now we are into freezing weather .... this can be a number of things
that connector looks like it should push on to a round turret connector, but those usually have 2 metal pieces in them or possibly a ring one to allow it to hold in place, this could be why its come off
once you have tried tracing it, stick a multi meter on it, lets see what you get on that line and when :)
Gunslinger
Postby Aztran » Thu Feb 02, 2006 11:18 am
Still cant work out where this goes :(
Aztran
Users browsing this forum: Jordan1994t
