The 'Cossybus'-updates!
Re: The 'Cossybus'-updates!
Postby Guy88 » Sat Apr 26, 2008 8:43 pm
theres a how to on ford power iirc
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby OxtonyxO » Sat Apr 26, 2008 8:46 pm
Mine was stalling when i was driving it due to the vss not being connected
Have you checked all the hoses for an air leak, as this can cause it to run rough due to unmetered air getting in.
i found two small pipe stubs on the side of the throttle that needed blanking off :idea:
if its stalling at idle then check all the connections to the iscv and hoses
OxtonyxO
Postby mantav8 » Sat Apr 26, 2008 8:56 pm
OxtonyxO wrote:Mine was stalling when i was driving it due to the vss not being connected
Hiya Tony, I have the Vss hooked up but it's not been driven yet to get a signal!-just fine when cold and as it warms up slows down and eventually cuts out,I did check all the vac connections and already blanked off the t/body ones.There is the servo take off,one at the rear of the Plenum to the Auto'box-is there any I'm missing? :roll:
mantav8
Cosworth Powered
Cosworth Powered
Postby Luke » Sat Apr 26, 2008 8:58 pm
one at the front right i think, also one underneith that goes to the n/s head, what did you do with the pipe from the o/s head to the air box :?:
Postby Guy88 » Sat Apr 26, 2008 8:59 pm
does it run if you hold the throttle open a touch
The VSS is only used on over run, and without it it can just die at a junction
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby OxtonyxO » Sat Apr 26, 2008 9:04 pm
what have you done with the hole and the small pipe at the rear of the plenum?
you can see the hole and the blanking pipe in the pic
does it run ok when cold?
does it rev alright?
it sounds like a problem with the idle control valve :!: IF there is no air leaks
this can be overiden if need be :D
OxtonyxO
Postby OxtonyxO » Sat Apr 26, 2008 9:18 pm
well i never new that!!
http://fordpower.org.uk/forum/index.php ... c=4985&hl=
have to remember that when i start mine tomorrow !!
never had any problems the first time :?:
OxtonyxO
Postby MrMPuk » Sat Apr 26, 2008 9:23 pm
OxtonyxO wrote:well i never new that!!
You have to be a member to read anything on Ford Power.
Postby mantav8 » Sat Apr 26, 2008 9:25 pm
Yes,the 300zx I had was the same,take off Battery for half an hour and clear the ECU!
I'll check for leaks tomorrow when I have fitted the exhaust back on!-could be the problem,we'll see! :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby OxtonyxO » Sat Apr 26, 2008 9:29 pm
sorry did not know that!!
fordpower wrote:Needs to be driven to re learn the ecu, if I remember right, start up hold a 1000rpm for a min then hold a 2000 rpm for a min then drive at least 5 miles mixed driving.
Mixture is none adjustable as is done by lambas/ecu
OxtonyxO
Postby mantav8 » Sun Apr 27, 2008 5:32 pm
looks like the idle is sorted!-made up a new section of exhaust as the other was blowing,pulled the KAM fuse and run it up as above.even managed a trip round the block and found the speedo inop!!(posted another thread on this)
Anyways,didn't get into fourth but changes are smooth,seems to do what it's suppoed to!
OH!-and fitted this today,crappy thing is about 600rpm out!
Back together!
:mrgreen:
Things to do-try and squeeze a leccy fan in!-don't think I need it here but will be peace of mind in Spain!-And sort the speedo! :roll:
mantav8
Cosworth Powered
Cosworth Powered
Postby madmark » Sun Apr 27, 2008 5:38 pm
:shock: wow mate this is very impresive ! :wink:
Postby mantav8 » Sun Apr 27, 2008 5:49 pm
madmark wrote::shock: wow mate this is very impresive ! :wink:
Would be more impressive with a speedo! LOL! :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby custom » Sun Apr 27, 2008 8:12 pm
thats very tidy mate have u any detailed pics of the rad as i need to change mine its soo big its from a sierra rs500 and i want a proper transit one
custom
Postby OxtonyxO » Sun Apr 27, 2008 8:14 pm
its just an efi mk5 rad, as fitted to the petrol dohc trannys
OxtonyxO
