van pulls to the left!
Postby madmark » Sun Feb 12, 2006 12:23 am
my mk5 pulls to the left when you let go of the wheel , i have had new tryes ,trancking checked etc any idea????? the fitter at fords said it might be bottom ball joints would that make it pull to the left???????? :?
Postby Andrew-v4 » Sun Feb 12, 2006 12:50 am
Best idea mark is not to let go of the wheel :lol:
Andrew-v4
Postby MrMPuk » Sun Feb 12, 2006 12:59 am
How did they check the tracking? Also a seized caliper could cause this.
Postby gemini » Sun Feb 12, 2006 1:30 am
i would say the tracking is towing out slightly, have it checked again somewhere else, guide is -1mm to +1mm, mine is set to 0 and seems fine
gemini
Postby madmark » Sun Feb 12, 2006 12:11 pm
:shock: it was done at fords! he gave it a lttle tweek but has made no difrents ! :? he said he thuort the bottom balljionts might be stiff causeing this , as the steering doesnt return how it should when on full lock! :?
Postby Luke » Sun Feb 12, 2006 12:13 pm
madmark wrote::shock: it was done at fords! he gave it a lttle tweek but has made no difrents ! :? he said he thuort the bottom balljionts might be stiff causeing this , as the steering doesnt return how it should when on full lock! :?
why dont you do the btm ball joints mark ? there only £8 each :D
Postby MrMPuk » Sun Feb 12, 2006 12:15 pm
Just because Fords did it don't mean it's right! You'd be better of at a tyre place!
Postby gemini » Sun Feb 12, 2006 12:49 pm
i agree, specially now you have said about the steering not returning correctly, if you are in reversing and on full lock does it pull the wheel into full lock
gemini
Postby madmark » Sun Feb 12, 2006 3:08 pm
:? not shure but even the steering does feel abit tight even tho its got pas its heavyish! :?
Postby crazyscoot » Sun Feb 12, 2006 6:56 pm
ball joints......jack front end up.........twist wheels back and fourth.......is it grinding and stiff? should be smooth. It will be stiff as you twist because your twisting both wheels at the same time through the steering rack but it shouldnt be overly stiff
Negative reality inversion
crazyscoot
Postby FredTransit » Sun Feb 12, 2006 7:00 pm
shouldn't this be in technical?
FredTransit
Mk2 Trannyist
Postby madmark » Sun Feb 12, 2006 7:28 pm
:shock: no idea fred! :?
Postby Luke » Sun Feb 12, 2006 9:19 pm
FredTransit wrote:shouldn't this be in technical?
ill move it :wink:
cron
