MK5 Chipped key
MK5 Chipped key
Postby Buzz-Billsberry » Mon Feb 13, 2006 11:11 pm
Need to buy new keys for spares etc but the red key didn't come with the van.Is there any way round it. I really don't want to buy another barrel set or pay my local ford dealer £65 for re chip + 18 per Key!!
The only thing I was thinking was just get a SET OF STANDARD keys cut and keep the chipped key in the van just for starting?
U might be thinking security and all that but the van is either gonna be kept in a locked compound or at a circuit, its not as if its gonna be left anywhere etc so the key can be well hid in the van
Buzz
I love food, its all I eat!
Buzz-Billsberry
Re: MK5 Chipped key
Postby tim » Mon Feb 13, 2006 11:24 pm
Buzz-Billsberry wrote:Need to buy new keys for spares etc but the red key didn't come with the van.Is there any way round it. I really don't want to buy another barrel set or pay my local ford dealer £65 for re chip + 18 per Key!!
Buzz
Tape the chipped key under the the steering column trim as close as you can to the ignition switch then you can use the key you have got cut to start and lock the van.The chipped key only sends a signal to the reciever which is fitted over the ignition
A WORK OF ART IS A JOY FOREVER
tim
Postby MrMPuk » Mon Feb 13, 2006 11:29 pm
Or even beter just tape the chip to the reciever under the ignition couling, that way you haven't got to leave a key in the van!
Postby Buzz-Billsberry » Tue Feb 14, 2006 1:30 am
Cheers guys. Ref the keys can i get them from any key cutter or will it after be ford? not bought a vehicle key for absolute years!
Buzz
Buzz-Billsberry
Postby MrMPuk » Tue Feb 14, 2006 1:42 am
Any good key cutter/shoe repair man should be able to do the keys. Think I paid abit £8 last time I had some done.
Postby sidspop » Tue Feb 14, 2006 10:42 am
I have a similar problem, the key with the chip has worn that much that you cant see grooves. I was quoted 50+vat for a new one. Yesterday I left the van running, and needed something out the back, which was locked. So I pulled the keys out the ignition, and the van still ran. The key is that worn that it came out at posn2 on the ignition.
How close does the chipped key have to be to ignition to work. I'm starting to suspect that the red key has been hidden already.
Andy
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby Buzz-Billsberry » Tue Feb 14, 2006 1:01 pm
MrMPuk wrote:Any good key cutter/shoe repair man should be able to do the keys. Think I paid abit £8 last time I had some done.
cheers bud
Buzz-Billsberry
Postby davek » Tue Feb 14, 2006 8:12 pm
The van (pats system) only looks at the key for start up - thats why the van will keep running when the key came out - you can get keys from a lock smith that have a screw holding the case together-cut the case of your old key and place chip in new to new key
davek
Postby MrMPuk » Wed Feb 15, 2006 12:24 am
davek wrote:The van (pats system) only looks at the key for start up - thats why the van will keep running when the key came out - you can get keys from a lock smith that have a screw holding the case together-cut the case of your old key and place chip in new to new key
But that means he still only has one key! The idea is he wants spares! To get the chip out you don't need to cut the key just dig out the red or blue tap on top.
cron
