mk4 LWB Project! UP DATE! one side nerly done in blue !!!
Re: !!Intransit89 LWB MK4 Project!!cab lights on :)
Postby intransit89 » Sat Jun 07, 2008 5:19 pm
well thay come to do so i put them on :D
i tock the head lining out 1st and then drilled holes and then wired them up wires go down the window plastic trim then tho the engine bulkhead to the parking light wired them of that both sides :wink:
pics bit crap but will wait till dark to see what thay look like :D
intransit89
Postby intransit89 » Sat Jun 07, 2008 9:57 pm
night time :D 8)
intransit89
Re: !!Intransit89 LWB MK4 Project!!cab lights on night time :)
Postby millertime_1985 » Sat Jun 07, 2008 10:26 pm
it would look better if the headlights were fitted and working too :)
Its Not a Van..... Its a Transit
millertime_1985
Postby intransit89 » Sat Jun 07, 2008 10:35 pm
millertime_1985 wrote:it would look better if the headlights were fitted and working too :)
haha i will fit them latter on.......tho the year :oops:
intransit89
Postby intransit89 » Sat Jun 07, 2008 11:33 pm
also to day i had a go at making a chassis section for in front of the rear spring hanger that goes from the main chassis beam to the side of the back rear quoter :wink:
fair play it isnt very good but was a 1st try :) will probably make a better one out of the 2m in 3 strips and then seam weld them :wink: 8)
this was just out of a flat sheet as some one told me but cant rember who that you can bend metal sheets by having a other thicker one on top and useing a club hammer so had a try :oops:
this what i come up with :wink:
intransit89
Postby dachre » Sun Jun 08, 2008 12:03 am
[quote="intransit89"]also to day i had a go at making a chassis section for in front of the rear spring hanger that goes from the main chassis beam to the side of the back rear quoter :wink:
quote]
Hey Inti,
Thats a really good bit of sheet metal fabrication you've got going there. Clean the paint off and weld it in and it'll be better than new... :D :D :D
Keep it up Inti.
dachre
Postby intransit89 » Sun Jun 08, 2008 12:13 am
dachre wrote:
intransit89 wrote:also to day i had a go at making a chassis section for in front of the rear spring hanger that goes from the main chassis beam to the side of the back rear quoter :wink:
quote]
Hey Inti,
Keep it up Inti.
lol i would perfer to make it out of 2mm as i made my own 2 rear spring hangers! out of 2mm and daves and when you go in the gravel carpark and a stone hits the spring hangers you should hear the ting sound :lol: 8)
intransit89
Postby transit killer » Sun Jun 08, 2008 12:18 am
Are you doing both hangers or just the one Rob? :?:
2004 Transit 350 LWB Recovery
transit killer
Postby intransit89 » Sun Jun 08, 2008 12:24 am
transit killer wrote:Are you doing both hangers or just the one Rob? :?:
erm well the drivers side need doing most but seeing as i got the pass inside rear back quotor done i might do the spring hanger on that side after i get the drivers side done as i go along the rear cross member to the pass side :lol: :wink: the spring hanger on pass side seems solid but might as well do it then it be rot free for a tho years as you know living by the sea kills transits :x
intransit89
Re: !!Intransit89 LWB MK4 Project!!started the front bumper :)
Postby intransit89 » Sun Jun 08, 2008 9:47 pm
geting it all sanded back to plastic and then filling all the scratchers then maybe decide if i want to make a longer bumper before i start to spray plastic primer on etc :wink:
intransit89
Re: !!Intransit89 LWB MK4 Project!!started making my bed/storage
Postby intransit89 » Tue Jun 10, 2008 8:10 pm
today from 10am till 4pm i maded this its a bed and under is for storage :wink:
just need to carpet the front and then put the door hinders x2 on and thats that done
heres pics 8)
brillant thing them bansaws 8) saves using the wood saw :roll: :x :D
8) very nice in side there needs a caravan air vent i think next :wink:
intransit89
Postby intransit89 » Tue Jun 10, 2008 10:21 pm
just put my door hinders on now just need to get some spray on glue for the carpet :D
:wink:
intransit89
Postby intransit89 » Wed Jun 11, 2008 2:23 pm
some new tools :D
the red tin is worth 90 on it own with out the tools :D
defo gona save up for one of these rac to
http://www.argos.co.uk/static/Product/p ... %3ERAC.htm
8)
intransit89
Postby sc_BK » Wed Jun 11, 2008 4:28 pm
intransit89 wrote: defo gona save up for one of these rac to
You could buy 2 driving lessons for that much money, AND have change! :shock:
If you need somewhere to store tools go down your local car boot sale and buy someone's old MFI wooden chest of drawers for about a fiver. Would probably be stronger than that £50 tin one aswell
sc_BK
Postby BILLY BOY » Wed Jun 11, 2008 6:21 pm
top job there rob. :D
cheers billy boy
03, 100ps 280
96, 190,lwb, td,
BILLY BOY
