MK2 and MT75
MK2 and MT75
Postby Barracuda » Thu Feb 16, 2006 11:06 am
Hello there!
Have somebody put a Mt75 gearbox in a MK2 and have some pics about it?
I have a MK2 with the 2L OHC and i want to put in a MT75 because the type9 is apparently not very strong....the second one is gone now.
Greeting
Matthias
Barracuda
Postby Pinto » Thu Feb 16, 2006 11:51 am
should fit easily enough, tho i dont know anything about the conversion. I was going to do my Mk2, but its being sold on now.
Need the prop, gearbox and adaptor plate, and possibly the flyweel and starter from a Pinto/DOHC mk3/4 :)
Pinto
Postby FredTransit » Thu Feb 16, 2006 2:36 pm
Have a look HERE
FredTransit
Mk2 Trannyist
Postby Barracuda » Thu Feb 16, 2006 3:30 pm
Hey, thank you.
But what's about the cardan shaft? The MT75 is shorter than the t9, isn't it?
Barracuda
Postby madmark » Thu Feb 16, 2006 3:32 pm
you will need the hole lot from a mt75 2ltr traNsit, and then you will have to moddify the floor abit! :)
Postby Luke » Thu Feb 16, 2006 6:11 pm
Barracuda wrote:Hey, thank you.
cardan shaft we call it a prop shaft!! :D
yes! you will need to modify the front end as the gearboxes are different!!! :D
Return to Mk 1 & 2
