Extra Windows
Extra Windows
Postby Rifleman » Sun Mar 13, 2005 11:32 pm
Anyone got any advice on the best / cheapest place to get two extra windows fitted in my van?, Its the two sliding doors I want to glaze, any ideas on where and how much??
Steve
Rifleman
Postby FredTransit » Sun Mar 13, 2005 11:39 pm
I would start with a wander round a large breakers (little ones won't keep vans n campers). Look for a camper or minibus and check out how the windows are fitted (as long as thay are not too big). Failing that, have you tried a local autoglass fitters, for the rubber fitting gromet. No harm in asking of you can buy the stuff by the foot, if available. As for the glass, a mini bus would be the best sourse.
FredTransit
Mk2 Trannyist
Postby Luke » Sun Mar 13, 2005 11:56 pm
can't you swap the doors for minibus type with the window allready in? the nearside would be fairly easy to get! not to sure about the off side one though i think 99% of minibus's were single door!
Postby madmark » Mon Mar 14, 2005 8:16 pm
steve i am shure i have seen 2 side opening windows on ebay yesterday!
Re: Extra Windows
Postby midniteclassix » Fri Mar 25, 2005 6:08 pm
Rifleman wrote:Anyone got any advice on the best / cheapest place to get two extra windows fitted in my van?, Its the two sliding doors I want to glaze, any ideas on where and how much??
Steve
hi i have some glass that came from a dormobole camper this is the glass from the sides of the camper if these are any good
old ford never die THEY JUST RUST AND FALL APART
midniteclassix
Postby Gunslinger » Sun Apr 03, 2005 3:41 pm
my suggestion on this will depend on your model of van .... i know it works on a mkII, but will depend what curve you have on yours,
I used solid windows from an LDV 400 or convoy, these are flat left to right but curved just right in the vertical plain and very, very easy to fit,
1) Remove the rubber strip from around the glass
2) drill out the rivets
3) rremove whole unit all in one :)
4) make a template of the hole
5) trace hole using template on your door
6) put whole window unit into new hole, and mark rivet holes
7) remove window and drill holes
8) add sealant if you wish then replace the window assy and rivet the new window/frame in place and replace rubber strip
viola .... works a treat on a mkII minibus .... no opening quarter panel windows, and these are a little bigger so if original ones are rusty around fitting edge .... no worries as you cut this section out when opening hole out :)
also available in different sizes .... LDV 400 rear ones are bigger, good for O/S, whereas, middle ones are shrter and good for doors on N/S
oh .... and forget to say, these also veryyyyy cheap and lots of them at breakers yards :)
Gunslinger
Postby DOL » Sat Apr 16, 2005 11:01 pm
RIFLEMAN I OWN A 1998 TRANSIT AND FITTED SLIDING SIDE WINDOWS MYSELF,ON THE INSIDE THERE IS A LIP JUST GRIND OR CUT ROUND THAT AND THE WINDOWS WILL FIT THEY WILL BE TIGHT TO GO IN BUT THEY DO IVE DONE IT TO 3 OF MY LAST TRANSITS
Image 1 by 1 the penguins keep stealing my sanity!!
DOL
Formerly known as Dafodol.
