swb day van project , WELL CRUNCH TIME, LAST CHANCE FOR BITS
Re: swb day van project MORE new bits
Postby spudmab » Mon Jul 07, 2008 11:16 am
i have been doing a few small jobs on my van to get it ready for gaydon, i have now got a running water surply and some line-o over the wood around the kitchen area,
i have also done some things that i thought will make it look a bit better and to save the bordem, i also forgot that i had to change the head unit i brought as it started to mess around, so i went and got a alpine unit insted,
i have also managed to get a flat screen moniter (15") ad took it apart and wired it up so it will run of a 12volt battery, just need to work out how i am going to fit it in the back of my van,
and just a pic to show the guages in and working the blue light is so bright at night need to tone it down a bit,
spudmab
Postby reaper » Mon Jul 07, 2008 6:19 pm
i am like'in those gauges mate and the head unit top job :D want to do mine
reaper
Postby Gurj51ngh » Mon Jul 07, 2008 7:11 pm
like the gauges mate!! top job still need to fit my boost gauge. were the other gauges easy to fit??
Gurj51ngh
Forums Loudest Van!
Re: swb day van project , computer now fitted
Postby spudmab » Tue Jul 08, 2008 12:16 pm
the guages where easy to do the longest part was running all the wiring loom, i picked up the temp wire from the standard loom, and the oil guage comes with a sensor 1/8th npt and just remove your stand oil pressure light switch and fit the new one, or you can buy a T piece witch lets you run both the sensor and switch,
any way back to what ihave been doing, last night i started to sort out the moniter and some lights, and i have just finished it off, all wired up and working,
spudmab
Postby custom » Tue Jul 08, 2008 1:15 pm
that looks sweet mate how hard is it to rewire the screen to 12v instead of 240? as i want to replace my kids motorised flip down 7 inch screen for a 17" one i can get cheep cheep very cheep
custom
Postby Ucof » Tue Jul 08, 2008 2:59 pm
That looks f*cking awesome :D
I was wondering how hard it was to switch to 12v too. I'd be interested in doing something like that.
In van Wardriving :D
Then hopefully in van Warcrafting ;)
1991 MK3 SWB Low Roof 120 2.0Ltr Pinto (not for much longer :( )
Scientists have proven that the awesomeness of a forum thread is directly proportional to the number of pictures it contains.
Ucof
Powered by Nutella
Postby intransit89 » Tue Jul 08, 2008 9:28 pm
inverter :?:
intransit89
Postby Luke » Tue Jul 08, 2008 9:51 pm
nice work spudmab 8)
Postby spudmab » Wed Jul 09, 2008 9:46 am
no inverter just found a moniter that has a 12volt input and striped the back off and worked out what i had to do and rewired it to work, have had it running and 12volt for about 3hours and no problems, so i hope its going to be all good,
i was worried about the fact that most batteries are about 13.5 volts but it doesn't seem to make that much of a difference and at the end of the day after the screen has been on for a bit the batteries will soon be down at 12 volts,
:lol: :lol:
spudmab
Postby spudmab » Fri Jul 18, 2008 9:15 am
well the weekend of camping i needed to rewire the control switches as they where a pain to get to when the bed was made so i moved every thing about and used another 24 meters of wire and run all the electricsup to the side panel
i also made the second half of my head lining and carpeted it to match the head lining above the cab,
i also wanted to make the exhaust more noise so out came the center box and that has made a lot of difference well happy, its only a temp bit of exhaust until i turbo it and make a full stainless steel exhaust,
spudmab
Postby MR BigBeefy LDV Guru » Fri Jul 18, 2008 11:57 am
looking good spud
i owe you one for defacing my pilot :twisted: :twisted: :twisted: :lol:
Transit dreamer!
Postby nip » Fri Jul 18, 2008 4:18 pm
top job your doing spud keep on it 8)
turbo powerd transit
nip
Postby evans88 » Sat Jul 19, 2008 8:46 am
Did you know you can get a swivel for the front passenger seat which will provide much more room when camping? They are available from O Leary Motor Homes if you're interested.
evans88
Postby AlanN » Sat Jul 19, 2008 9:06 am
Or look in early renault espace's they have swivel bases that can be fitted to most seats with some minor mods, the later ones are really hard to remove the seats. Also look at high end ford Galaxies, most of them have arm rests and tables on the back.
I brought a renault one from the breakers for £20
Postby dachre » Sat Jul 19, 2008 4:18 pm
I have a set of 360 degree universal swivel mechs to fit both front seats going spare. I bought them and was going to knock up a transit seat platform for them to put in my camper but i bought a set of Galaxy seats.... Thought id be posh and fit some pukka comfy seats instead..... :) .....
dachre
