cat removing
Re: cat removing
Postby belly » Wed Aug 13, 2008 6:56 pm
yeh thats very true, focus is basically the same lump isnt it? ive already thought about the focus but only tried to get a ready made de-cat ! will ring around again tommoz,and see whos got some focuses in then i can have a gander this wknd, i dont mind cutting mine open and getting on with it !! its just if i cock it up which is normally the case :roll: id rather do it to a old one and keep mine which i know is the correct fitment and works fine :D
belly
Kaiser Chief
Re: cat removing
Postby MrMPuk » Wed Aug 13, 2008 7:00 pm
You could always make one or have one made!
Re: cat removing
Postby belly » Wed Aug 13, 2008 7:13 pm
I did get a quote of £250+vat because the canister is straight onto the flange and would need a one off flange machined before any pipe fab :( the exhaust guys suggested just cut the innards out for ease and price :) depends how much for a second hand one in the first place really!plus im not sure how having a empty canister then going into ehaust would effect the gasflow as to say a straight even diameter pipe i cant remember if you need some backpressure or not after the turbo :? its being a while sinse my turbo days :D
belly
Kaiser Chief
Re: cat removing
Postby MrMPuk » Wed Aug 13, 2008 7:17 pm
Most decent exhaust places should have turbo flanges on the shelf.
Re: cat removing
Postby belly » Fri Aug 22, 2008 8:51 pm
well a little update as ive found another company that do custom exhaust fabrications 8) there called electromec and are just around the corner from me, popped in and spoke to them and im booked in next week to get the van up and on the ramps, havnt done a connect yet but have just done a fleet of mk6 transits that had there cats nicked from the clients yard :roll: seem very knowledgeable and professional :D
belly
Kaiser Chief
