Luke wrote:pritty sure he did them 20mm
yeah i think the head of the stud is 5mm and the gap is the same so once they are tapped in just tickle them up with the grinder if neededHaxman wrote:Luke wrote:pritty sure he did them 20mm
I recon you'd have to grind the end of the studs down if using 20mm adaptors as im sure the studs are longer then that, that shouldnt be a problem tho hey...
Luke wrote:one think i remember from measuring arch clearance is try both sides the tolerances with these old vans isnt that good and you might find the axles not central - i cant find the measurents i did but i took an average from both sides - mine was over 5mm out and a mk3 i had was summat like about 20mm out never fully investigated why but i presume it'd had some sort of accident damage
Haxman wrote:Does it matter that the wheels are not on the inside of the wheel arch in terms of arches rubbing the tyre? is that a risk??
no i dont ive been on about making one for yearsHaxman wrote:Hmm, neat but would that work with a a mk2 transit arch profile? It looks like it forms a perfect arc to me, the top of mk2 transit arch is pretty flat. Do you know any one whos had it done?
