whats this light
whats this light
Postby Husky » Wed Mar 01, 2006 8:08 pm
Hi -I've just done an oil change on my 94 mk5 and now sometimes when I rev it a light just under the temp gauge comes on -it looks like a jerry can with wavey lines in the bottom half-anyone know what this is please?.
Cheers Husky :?
Husky
Postby MrMPuk » Wed Mar 01, 2006 8:32 pm
Water in you washer bottle or in the fuel filter I would guess.
Postby Nighthawk » Wed Mar 01, 2006 11:25 pm
Water in fuel filter
caused by either water in the filter which needs draining off, or a fault in the wiring is shorting out when the engine moves.
drain it and see how it goes.. 8)
Nighthawk
Postby vanman06 » Wed Mar 01, 2006 11:55 pm
Ahh husky you seem to have the same prolem i do with my dads van.....See thread...Water in fuel filter water trap light.
cheers
Cheers,wayne
vanman06
Postby Husky » Thu Mar 02, 2006 9:17 pm
I'm puzzled-I only changed the oil-never drove the van or moved it,its only been started up and left ticking over for ten mins each day?.
husky :?
Husky
Postby Luke » Thu Mar 02, 2006 9:20 pm
Husky wrote:I'm puzzled-I only changed the oil-never drove the van or moved it,its only been started up and left ticking over for ten mins each day?.
husky :?
have you tried to drain it? was it that?
:D
Postby vanman06 » Thu Mar 02, 2006 9:45 pm
I tried to drain it but it was clear,now today i dicover it was a wiring fault whereby the previous owner had wrapped all three ends of the wires together creating a short thus allowing the light to be illuminated all the time....I suggest you do what i did today,start at the sensor plug at the bottom of the fuel filter and have a good check of all the wires there may be some touching somewhere...
Good luck,let us know how you get on
cheers
Cheers,wayne
vanman06
